> Carbs or Ing Sys, Intermittent miss-fire
Razorbobsr
post Mar 14 2011, 11:26 AM
As you guys said, cleaned jets in carb, replaced plugs and wires, smooth at 900 rpms in drive, smooth at 2/3/4 K rpms in driveway, pulls hard W/O, sill I have a miss-fire that I can feel coming and going[surging, sound of engine when all 4 hit at proper times] Could I have a coil prob? Or where off to next?? 2L/carbs/5K sense rebuild/1500 miles driven to get this car home..... NKG plugs but do have Bosh plugs waiting...... Getting warmer outside, Help! Bob PS, British car friends are starting to make fun of the 914........... AND ME
McMark
post Mar 16 2011, 11:24 AM
914 Freak!
On the mix screw
Turning in closes the the jet (less fuel and air)
Turning out opens the jet (more fuel and air)
the mix screw does not change the ratio of air to fuel, just the volume of it. The object of adjusting this screw is to get the cylinder to run smoothly on as little fuel and air as possible.
Zach, you're confusing two screws here. The idle mixture screws cange only the volume of fuel at idle. Screwing them in will make it run leaner, out is richer. This screw does not change airflow at idle. Right next to the idle mixture screw is an air bypass screw. This one has a lock nut on it and it changes that amount of air bypassing the throttle plate at idle. Screwing it out allows more air to pass, and in allows less. The air bypass screws need to be adjusted while the linkage is disconnected and with a UniSyn or Synchometer (better). The function of the air bypass screws is not to change mixture, but to equalize the air flow of the two throats.
You disconnect the bar by unbolting the drop links that go from the cross bar to the carb body. They are usually held on with small bolts (m4 or m5). Depending on the make of the bar, some have snap joints instead of bolts. Take a picture of your connection and we can help you out.
VaccaRabite
post Mar 16 2011, 07:34 PM
En Garde!
QUOTE(McMark @ Mar 16 2011, 12:24 PM) *
(IMG:http://www.914world.com/bbs2/uploads_offsite/th192.photobucket.com-1435-1300325684.1.jpg)
WTF was I thinking? I seriously need to get out and play with my car, I am way out of practice here.
Razor,
From your other post, I think you are using a Eurorace header. If it has the turbo muffler, there is not much going on inside it. Part of the reason its so loud.
Zach
Razorbobsr   Carbs or Ing Sys   Mar 14 2011, 11:26 AM
Vacca Rabite   Where in the rpm range is it missing? Is it missi...   Mar 14 2011, 04:10 PM
Razorbobsr   Where in the rpm range is it missing? Is it miss...   Mar 14 2011, 04:58 PM
Vacca Rabite   Can you get it to miss sitting in your driveway? ...   Mar 14 2011, 07:31 PM
Razorbobsr   Can you get it to miss sitting in your driveway? ...   Mar 14 2011, 09:04 PM
Vacca Rabite   Coils usually either work or don't work. I...   Mar 15 2011, 08:04 AM
Razorbobsr   Coils usually either work or don't work. I...   Mar 15 2011, 10:34 AM
Razorbobsr   Coils usually either work or don't work. I...   Mar 16 2011, 08:57 AM
indianmort   if the misfire develops after the car has warmed u...   Mar 15 2011, 08:23 AM
Razorbobsr   if the misfire develops after the car has warmed ...   Mar 15 2011, 11:39 AM
Borderline   How did you synch the carbs/linkage? I have found...   Mar 15 2011, 10:24 AM
Razorbobsr   How did you synch the carbs/linkage? I have foun...   Mar 15 2011, 11:36 AM
McMark   009 Dizzy is garbage. As Dave Darling loves to sa...   Mar 15 2011, 11:42 AM
Razorbobsr   009 Dizzy is garbage. As Dave Darling loves to s...   Mar 15 2011, 01:37 PM
McMark   Normally I retype all this info. But there is so ...   Mar 15 2011, 02:33 PM
Razorbobsr   Normally I retype all this info. But there is so...   Mar 16 2011, 06:18 AM
Vacca Rabite   Always adjust carbs when they are fully warmed up....   Mar 16 2011, 09:30 AM
Razorbobsr   Always adjust carbs when they are fully warmed up...   Mar 16 2011, 02:42 PM
McMark   Zach, you're confusing two screws here. The ...   Mar 16 2011, 11:24 AM
Vacca Rabite   Zach, you're confusing two screws here. The...   Mar 16 2011, 07:34 PM
- Lo-Fi Version Time is now: 7th July 2025 - 02:26 PM
