Carb Airbox, Input appreciated... |
stepuptotheMike |
May 16 2009, 07:04 AM
medium pimpin Group: Members Posts: 565 Joined: 4-September 06 From: Charlotte, NC Member No.: 6,769 Region Association: South East States |
So I have Weber 44s on my car. When the installation was done by a previous, previous owner, there were some aspects that were less than detail oriented. Items such as the following:
-Fuel Vapor lines from the front (car is a 73) just dump into the engine compartment. Assuming this contributes to fuel smell in car. -Crank vent is basically a hose with a tiny air filter on it, suspended over the engine case... this leads to oil film all over. - No head breather ports. Heads were never drilled/tapped for them, but I don't think my venting is adequate and it's causing oil leaks. - Carbs in general are just loud. I want to hear some throat when I get on it, but don't need it all the time. So in reading through various threads (especially the ones on the breather setups folks have posted recently) I started thinking about how I could solve all of these problems in 1. Creating a legal setup that would pull the fuel vapors and case/vents into the carb intakes..... and quieting things down a little bit. So I thought about creating a single airbox that would install over the combined carb setup. Ideally, I would think plastic would be the medium of choice, but I have no clue where I would start.... so then I started thinking about fiberglass. Granted, I've never really built anything with glass, but it's fairly cheap and if it doesn't work I figure I'm only out my time and a few bucks. Plus I learn something in the process. I figure I could use techniques similar to those that the custom speaker box guys use to form shapes and build the box. This would just be thinner. So I came up with the following crude drawing to illustrate kind of what I'm talking about. I would appreciate thoughts on this concept. Shoot holes in it as you see fit. Been down this road before? Know somebody that tried something similar? Thanks in advance.... Mike |
VaccaRabite |
Mar 17 2011, 07:29 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I'd be interested. The 912 cleaners are heavy.
BAM, where does the filter go? K&Ns on each side, or a panel filter somewhere? Zach |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:23 PM |
