> Gint just left from my house
weird_looking_cactus
post Apr 4 2004, 07:53 PM
Cactus
Gint made it by my house today. He check out alot of things like my rust problem is not that bad. That on one side my car some one flared out my fender so it makes my wheels look of alinment. Help me put in the supports on my gas tanks. Told me how to fix my doors. Told me how to put new transmission fluid in. Found out why my car is idleing high. Plus answered all my questions. Im stick stuck on fixing my gears cause he said he's never messed with that stuff before. Now when I try to switch it into reverise it goes into second gear. I just need to adjustest it. But anyways Thanks GINT (MIKE). (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/laugh.gif)
post Apr 4 2004, 09:54 PM
Resident German
first, make sure that little allen screw on the shitfer coupler right behind the firewall is tight.
then, get inside the car and remove the square cover from the center tuneel right before the firewall.
then, loosen the nut that holds the shiftrod to the shifter (through the little opening behind the shifter).
then, use one hand to SLOWLY rotate the shiftrod (through the hole near the rear firewall) and use the other hand to tighten the nut back in the front.
try shifting through the gears and repeat as needed until all gears work fine ...
Andy
weird_looking_cactus   Gint just left from my house   Apr 4 2004, 07:53 PM
Bleyseng   Good to hear you are making some progress! Lit...   Apr 4 2004, 08:01 PM
markb   It makes life so much better when you have someone...   Apr 4 2004, 08:55 PM
weird_looking_cactus   Yep he is a good guy. I probley have another coupl...   Apr 4 2004, 09:03 PM
nebreitling   WAY TO GO, GUYS! :headbanger: sounds like ...   Apr 4 2004, 09:04 PM
GWN7   So is it the shifter linkage or the trans that...   Apr 4 2004, 09:37 PM
weird_looking_cactus   Im not sure cause before I had it shifting into se...   Apr 4 2004, 09:45 PM
SirAndy   first, make sure that little allen screw on the sh...   Apr 4 2004, 09:54 PM
Racer Chris     Apr 4 2004, 10:00 PM
Malmz   Dang, he's making good time in that rent car.....   Apr 4 2004, 10:10 PM
rhodyguy   i was afraid you were going to tell us "mike said ...   Apr 5 2004, 06:05 AM
Gint   Stop and go traffic on the 15 east of Baker. 3 ac...   Apr 5 2004, 09:53 AM
!   Yo cactus.....415PB has a sawzall candidate in the...   Apr 5 2004, 10:07 AM
Dave_Darling   Check the "shifting improvements" tech article on ...   Apr 5 2004, 12:01 PM
SpecialK   Okay, I'm confused :idea: 'Gint' liv...   Apr 5 2004, 05:23 PM
weird_looking_cactus   Im making some progress on the gears. Cause now it...   Apr 5 2004, 07:00 PM
Malmz   ...   Apr 5 2004, 07:00 PM
trojanhorsepower   Man Cactus, that is weird. Just a thought, I woul...   Apr 5 2004, 07:09 PM
Malmz     Apr 5 2004, 07:28 PM
weird_looking_cactus   So im thinking I need a new transmission now. I ha...   Apr 5 2004, 09:03 PM
Malmz   Guarantee is good, and they have good feedback. I...   Apr 5 2004, 09:13 PM
weird_looking_cactus   Haha I said that someone might be stoping by today...   Apr 5 2004, 09:25 PM
Gint   Kris's dad seems to be retty supportive of his...   Apr 5 2004, 09:55 PM
Bleyseng   Good idea Gint as lots of us have garages full of ...   Apr 5 2004, 10:01 PM
Gint   You're not that from from Salt Lake either. T...   Apr 5 2004, 10:04 PM
Malmz
  Apr 5 2004, 10:14 PM
Racer Chris   There is at least a possibility the shift fork ins...   Apr 5 2004, 10:30 PM
GWN7   The ebay auction...read the shipping information b...   Apr 5 2004, 10:31 PM
Gint   That could very well be the guy Kris heard about i...   Apr 5 2004, 10:33 PM
weird_looking_cactus   The guy thats suppose to have a couple 914s shoul...   Apr 5 2004, 10:39 PM
Bleyseng   How did you find your 914?   Apr 5 2004, 10:44 PM
weird_looking_cactus   The guy down the street from me had it parked out...   Apr 5 2004, 10:50 PM
GWN7   He may have a V8 car now. (not sure) He's sort...   Apr 6 2004, 12:34 AM
Racer Chris   You have to expect that a $700 914 that sat f...   Apr 6 2004, 05:44 AM
Eric_Shea   Cacti... I may have a side shifter here for ya. ...   Apr 6 2004, 08:14 AM
!   Eric....want to expand on that? You re using and ...   Apr 6 2004, 08:18 AM
Eric_Shea   They came on the 70-71 MY cars. It was when they ...   Apr 6 2004, 08:52 AM
weird_looking_cactus   Well I have kinda bad news. If my problem is my tr...   Apr 7 2004, 06:24 PM
lapuwali   This doesn't sound like a transmission problem...   Apr 7 2004, 06:38 PM
Malmz   Dooood. You have to be going from 1st to 4th, or ...   Apr 7 2004, 06:40 PM
weird_looking_cactus   I know its running on all 4 cylenders cause I che...   Apr 7 2004, 06:47 PM
weird_looking_cactus   anther pics of second gear   Apr 7 2004, 06:48 PM
weird_looking_cactus   Im not sure how to get to the adjust part between ...   Apr 7 2004, 06:51 PM
Malmz   At the tranny, it should be in the middle position...   Apr 7 2004, 06:59 PM
Malmz   It's the clamp right behind the shift lever. ...   Apr 7 2004, 07:04 PM
nebreitling   :agree: sounds like the shifter just needs [majo...   Apr 7 2004, 07:17 PM
weird_looking_cactus   Haha well then my car is going into 5th gear not s...   Apr 7 2004, 07:19 PM
Malmz   Half way out. sm   Apr 7 2004, 07:24 PM
Hawktel   If you get Eric's Transmission, on the 22nd of...   Apr 7 2004, 07:48 PM
weird_looking_cactus   I don't think I need a transmission I still ca...   Apr 7 2004, 07:57 PM
Malmz   Just to confirm since you haven't driven a 914...   Apr 7 2004, 08:03 PM
Gint   OK, let me chime in here now that I have a few min...   Apr 7 2004, 08:03 PM
Gint   LOL - Kris doesn't have a shift knob. Too bad...   Apr 7 2004, 08:07 PM
Bleyseng   This is my car and the shifter is in 1st gear. Se...   Apr 7 2004, 08:19 PM
weird_looking_cactus   Ok I have been driving it around for a couple hour...   Apr 7 2004, 08:21 PM
weird_looking_cactus   I need to replace a couple fuses cause I burn...   Apr 7 2004, 08:31 PM
Gint   Fuse layout   Apr 7 2004, 08:40 PM
Malmz
- Lo-Fi Version Time is now: 14th July 2025 - 01:13 AM
