weird_looking_cactus |
Cactus ![]() ![]() Group: Members Posts: 225 Joined: 16-February 04 From: St, George UT Member No.: 1,660 ![]() |
Gint made it by my house today. He check out alot of things like my rust problem is not that bad. That on one side my car some one flared out my fender so it makes my wheels look of alinment. Help me put in the supports on my gas tanks. Told me how to fix my doors. Told me how to put new transmission fluid in. Found out why my car is idleing high. Plus answered all my questions. Im stick stuck on fixing my gears cause he said he's never messed with that stuff before. Now when I try to switch it into reverise it goes into second gear. I just need to adjustest it. But anyways Thanks GINT (MIKE). (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/laugh.gif)
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,990 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
QUOTE(SirAndy @ Apr 4 2004, 11:54 PM) use one hand to SLOWLY rotate the shiftrod (through the hole near the rear firewall) and use the other hand to tighten the nut back in the front. There are splines where the rod enters the connector under the shift lever. You only want to rotate it one spline at a time, then test before changing again. |
Lo-Fi Version | Time is now: 14th July 2025 - 12:29 AM |
