| mightyohm |
Apr 5 2004, 10:40 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,279 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
I am putting 96mm KB's into a 2.0 liter motor, stock crank, stock rods, heads will only have slight flycut (just enough to get sealing surfaces back). Cylinders are stock 94's bored out to 96.
What will my compression ratio be? I know this is a combo that many have looked at or built before. Maybe someone knows or has measured. I want to get an idea of where I will be with no additional mods. |
| Dave_Darling |
Apr 5 2004, 11:44 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
A head C kit is really complex, I don't know if you want to try to make it yourself.
You need: * A round piece of plexiglass the same size as the cylinder "register" in the heads. With two holes, one to fill through and one for air to escape. * A graduated cylinder or pipette from a chemistry supply store. * Some liquid. As you see, very complex and difficult to find parts.... (IMG:style_emoticons/default/rolleyes.gif) --DD |
jkeyzer what will my compression ratio be Apr 5 2004, 10:40 AM
Mark Henry So class, here is the math quiz of the day.
Engi... Apr 5 2004, 11:00 AM
Mueller Jeff,
the problem is whether or not your heads ha... Apr 5 2004, 11:08 AM
Jake Raby Do NOT GUESS AT CHAMBER VOLUME! 1 cc means a w... Apr 5 2004, 11:21 AM
Mark Henry :agree:
Even stock uncut heads can be 2-4 cc dif... Apr 5 2004, 11:28 AM
jkeyzer I was not looking for an exact number but wanted t... Apr 5 2004, 11:39 AM
jkeyzer Ok so who wants to cut a perfectly round piece of ... Apr 5 2004, 11:49 AM
Mueller Jeff,
I have a CC kit, you can use it as long as ... Apr 5 2004, 12:30 PM
Mark Henry Dave's way is being a bit of a TW ;)
Just go... Apr 5 2004, 12:33 PM
Mueller no need to have a round piece.......you can place ... Apr 5 2004, 12:42 PM
jkeyzer Mike, why superclean? Apr 5 2004, 12:45 PM
Brett W Depending on deck height and chamber volumn you ar... Apr 5 2004, 12:54 PM
TonyAKAVW The answer is 42:1...
but what is the question... Apr 5 2004, 12:57 PM
jkeyzer
James Adams
MarkV You can get a kit here:
http://www.vwalley.com/ Apr 5 2004, 01:29 PM
cgnj I'd ask them for the chamber volume. I still c... Apr 5 2004, 04:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:35 PM |
