| mightyohm |
Apr 5 2004, 10:40 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,279 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
I am putting 96mm KB's into a 2.0 liter motor, stock crank, stock rods, heads will only have slight flycut (just enough to get sealing surfaces back). Cylinders are stock 94's bored out to 96.
What will my compression ratio be? I know this is a combo that many have looked at or built before. Maybe someone knows or has measured. I want to get an idea of where I will be with no additional mods. |
| Mark Henry |
Apr 5 2004, 12:33 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Dave's way is being a bit of a TW (IMG:style_emoticons/default/wink.gif)
Just go to a VW bug shop and get a head cc kit for 94mm cylinder. It might not fit perfect but it will work. About $20. Put a smear of grease on the outer edge of the plate to make the seal, then just use water in the syringe that comes with the kit. When you clean up just make sure to blow out the water. |
jkeyzer what will my compression ratio be Apr 5 2004, 10:40 AM
Mark Henry So class, here is the math quiz of the day.
Engi... Apr 5 2004, 11:00 AM
Mueller Jeff,
the problem is whether or not your heads ha... Apr 5 2004, 11:08 AM
Jake Raby Do NOT GUESS AT CHAMBER VOLUME! 1 cc means a w... Apr 5 2004, 11:21 AM
Mark Henry :agree:
Even stock uncut heads can be 2-4 cc dif... Apr 5 2004, 11:28 AM
jkeyzer I was not looking for an exact number but wanted t... Apr 5 2004, 11:39 AM
Dave_Darling A head C kit is really complex, I don't know i... Apr 5 2004, 11:44 AM
jkeyzer Ok so who wants to cut a perfectly round piece of ... Apr 5 2004, 11:49 AM
Mueller Jeff,
I have a CC kit, you can use it as long as ... Apr 5 2004, 12:30 PM
Mueller no need to have a round piece.......you can place ... Apr 5 2004, 12:42 PM
jkeyzer Mike, why superclean? Apr 5 2004, 12:45 PM
Brett W Depending on deck height and chamber volumn you ar... Apr 5 2004, 12:54 PM
TonyAKAVW The answer is 42:1...
but what is the question... Apr 5 2004, 12:57 PM
jkeyzer
James Adams
MarkV You can get a kit here:
http://www.vwalley.com/ Apr 5 2004, 01:29 PM
cgnj I'd ask them for the chamber volume. I still c... Apr 5 2004, 04:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:58 PM |
