> what will my compression ratio be, maybe someone knows
mightyohm
post Apr 5 2004, 10:40 AM
I am putting 96mm KB's into a 2.0 liter motor, stock crank, stock rods, heads will only have slight flycut (just enough to get sealing surfaces back). Cylinders are stock 94's bored out to 96.
What will my compression ratio be?
I know this is a combo that many have looked at or built before. Maybe someone knows or has measured.
I want to get an idea of where I will be with no additional mods.
Brett W
post Apr 5 2004, 12:54 PM
Depending on deck height and chamber volumn you are looking at between 8.9-9.75:1. On engines with as big a bore as ours 1cc doesn't make that big of a difference, about a .10 of a point. Hit the site:
http://www.rbracing-rsr.com/compstaticcalc.html
The deck hieght will make a difference as well. If you want to measure your chamber volumn go to the vet and get the biggest syringe they have, take the needle out and get a piece of plexiglas to seal the top of the chamber. Fill the chamber and measure the amount from the ccs on the side of the syringe.
- Lo-Fi Version Time is now: 2nd April 2026 - 06:34 PM
