> what will my compression ratio be, maybe someone knows
mightyohm
post Apr 5 2004, 10:40 AM
I am putting 96mm KB's into a 2.0 liter motor, stock crank, stock rods, heads will only have slight flycut (just enough to get sealing surfaces back). Cylinders are stock 94's bored out to 96.
What will my compression ratio be?
I know this is a combo that many have looked at or built before. Maybe someone knows or has measured.
I want to get an idea of where I will be with no additional mods.
JWest
post Apr 5 2004, 01:05 PM
QUOTE(jkeyzer @ Apr 5 2004, 12:45 PM)
Mike, why superclean?
Low surface tension so you don't have a big bulge of water at the exit hole.. At the very least put some detergent in the water if you use that. Soap breaks surface tension.
- Lo-Fi Version Time is now: 2nd April 2026 - 04:58 PM
