> 930 trans inverted or right side up, cable shifter solution?
jimkelly
post Mar 26 2011, 06:45 PM
Delaware USA
http://www.cableshift.com/930/930%20page.html
http://www.californiamotorsports.net/930.htm
http://forums.pelicanparts.com/porsche-914...gine-trans.html
http://www.gt40s.com/forum/gt40-build-logs...chbuilt-15.html
http://www.pbase.com/9146gt/930_turbo_racing_gearbox
http://www.negativereinforcementracing.com/week23.htm
Dave_Darling
post Mar 26 2011, 11:02 PM
914 Idiot
I believe the housing has to be machined in order to flip the R&P. Oiling setup needs to be changed if you flip the whole box. Either can work; and it should survive a good amount of torque.
--DD
jimkelly   930 trans inverted or right side up   Mar 26 2011, 06:45 PM
kg6dxn   I don't think you can flop the ring/pinion so ...   Mar 26 2011, 07:47 PM
jmmotorsports   I don't think you can flop the ring/pinion so...   Mar 26 2011, 08:06 PM
jaminM3   California Motorsports can flip the 930 ring gea...   Mar 27 2011, 10:19 PM
Dave_Darling   I believe the housing has to be machined in order ...   Mar 26 2011, 11:02 PM
John   The case does need to be "clearanced" fo...   Mar 27 2011, 09:07 AM
pcar916   Inverting the 930 is easy to do, it was made with ...   Mar 27 2011, 09:19 AM
jimkelly   at $59.00 each for 108mm cvs - plus, axles, a...   Mar 27 2011, 09:36 AM
pcar916   at $59.00 each for 108mm cvs - plus, axles, ...   Mar 27 2011, 10:41 AM
Dr Evil   Yes, you can flip the diff in a 930, changing the ...   Mar 27 2011, 06:20 PM
jimkelly   pics please doc :worship: what year 930? :ide...   Mar 28 2011, 11:51 AM
jimkelly   info i have seen says the g50 much be installed up...   Mar 28 2011, 04:27 AM
pcar916   info i have seen says the g50 much be installed u...   Mar 28 2011, 11:36 AM
jimkelly   g50 shifts better than a 901 - that is a plus :dr...   Mar 28 2011, 11:49 AM
pcar916   The 930 and the 915 ar very similar (as the Doc ha...   Mar 28 2011, 04:15 PM
jimkelly   another wrinkle in installing a 930 trans is wheth...   Mar 28 2011, 05:26 PM
pcar916   Not a deal breaker. I like the both for different ...   Mar 28 2011, 05:57 PM
Britain Smith   I know this is an older thread...however several t...   Jul 1 2013, 11:04 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:21 AM
