| jimkelly |
Mar 26 2011, 06:45 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
http://www.cableshift.com/930/930%20page.html
http://www.californiamotorsports.net/930.htm http://forums.pelicanparts.com/porsche-914...gine-trans.html http://www.gt40s.com/forum/gt40-build-logs...chbuilt-15.html http://www.pbase.com/9146gt/930_turbo_racing_gearbox http://www.negativereinforcementracing.com/week23.htm |
| pcar916 |
Mar 27 2011, 09:19 AM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
Inverting the 930 is easy to do, it was made with that in mind. But the CV deflection angle will be pretty steep unless your car is lowered a lot because the output flanges will be considerably higher. I don't know what the angle will be (forgot) but you should measure and see if you'll need the larger angle the 108mm 930 cv's will give you. Without going out to the shop to measure the flanges will be about 4in higher in the car than before.
Someone else may have made a calculation on the horsepower loss developed by the new larger angle as well but I haven't done it. Good luck |
jimkelly 930 trans inverted or right side up Mar 26 2011, 06:45 PM
kg6dxn I don't think you can flop the ring/pinion so ... Mar 26 2011, 07:47 PM
jmmotorsports
I don't think you can flop the ring/pinion so... Mar 26 2011, 08:06 PM
jaminM3
California Motorsports can flip the 930 ring gea... Mar 27 2011, 10:19 PM
Dave_Darling I believe the housing has to be machined in order ... Mar 26 2011, 11:02 PM
John The case does need to be "clearanced" fo... Mar 27 2011, 09:07 AM
jimkelly at $59.00 each for 108mm cvs - plus, axles, a... Mar 27 2011, 09:36 AM
pcar916
at $59.00 each for 108mm cvs - plus, axles, ... Mar 27 2011, 10:41 AM
Dr Evil Yes, you can flip the diff in a 930, changing the ... Mar 27 2011, 06:20 PM
jimkelly pics please doc :worship:
what year 930?
:ide... Mar 28 2011, 11:51 AM
jimkelly info i have seen says the g50 much be installed up... Mar 28 2011, 04:27 AM
pcar916
info i have seen says the g50 much be installed u... Mar 28 2011, 11:36 AM
jimkelly g50 shifts better than a 901 - that is a plus :dr... Mar 28 2011, 11:49 AM
pcar916 The 930 and the 915 ar very similar (as the Doc ha... Mar 28 2011, 04:15 PM
jimkelly another wrinkle in installing a 930 trans is wheth... Mar 28 2011, 05:26 PM
pcar916 Not a deal breaker. I like the both for different ... Mar 28 2011, 05:57 PM
Britain Smith I know this is an older thread...however several t... Jul 1 2013, 11:04 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:26 PM |
