> 930 trans inverted or right side up, cable shifter solution?
jimkelly
post Mar 26 2011, 06:45 PM
Delaware USA
http://www.cableshift.com/930/930%20page.html
http://www.californiamotorsports.net/930.htm
http://forums.pelicanparts.com/porsche-914...gine-trans.html
http://www.gt40s.com/forum/gt40-build-logs...chbuilt-15.html
http://www.pbase.com/9146gt/930_turbo_racing_gearbox
http://www.negativereinforcementracing.com/week23.htm
Mike Bellis
post Mar 26 2011, 07:47 PM
Resident Electrician
I don't think you can flop the ring/pinion so you have to flip the tranny. You also need to deal with upsidedown lubrication. I would go with www.cableshift.com It looks like a good system and the price is resonable. Or fab your own system...
jmmotorsports
post Mar 26 2011, 08:06 PM
QUOTE(kg6dxn @ Mar 26 2011, 06:47 PM) *
California Motorsports can flip the 930 ring gear. G50 can't be flipped.
Jerry
jaminM3
post Mar 27 2011, 10:19 PM
QUOTE(jmmotorsports @ Mar 26 2011, 08:06 PM) *
Jerry
Factory Five does a their GTM Super car using Corvette parts and a G50 transaxle from Porsche. They must be running it upside down or flipping the ring to make it mid-engine...
...right? (IMG:style_emoticons/default/confused24.gif)
jimkelly   930 trans inverted or right side up   Mar 26 2011, 06:45 PM
kg6dxn   I don't think you can flop the ring/pinion so ...   Mar 26 2011, 07:47 PM
jmmotorsports   I don't think you can flop the ring/pinion so...   Mar 26 2011, 08:06 PM
jaminM3   California Motorsports can flip the 930 ring gea...   Mar 27 2011, 10:19 PM
Dave_Darling   I believe the housing has to be machined in order ...   Mar 26 2011, 11:02 PM
John   The case does need to be "clearanced" fo...   Mar 27 2011, 09:07 AM
pcar916   Inverting the 930 is easy to do, it was made with ...   Mar 27 2011, 09:19 AM
jimkelly   at $59.00 each for 108mm cvs - plus, axles, a...   Mar 27 2011, 09:36 AM
pcar916   at $59.00 each for 108mm cvs - plus, axles, ...   Mar 27 2011, 10:41 AM
Dr Evil   Yes, you can flip the diff in a 930, changing the ...   Mar 27 2011, 06:20 PM
jimkelly   pics please doc :worship: what year 930? :ide...   Mar 28 2011, 11:51 AM
jimkelly   info i have seen says the g50 much be installed up...   Mar 28 2011, 04:27 AM
pcar916   info i have seen says the g50 much be installed u...   Mar 28 2011, 11:36 AM
jimkelly   g50 shifts better than a 901 - that is a plus :dr...   Mar 28 2011, 11:49 AM
pcar916   The 930 and the 915 ar very similar (as the Doc ha...   Mar 28 2011, 04:15 PM
jimkelly   another wrinkle in installing a 930 trans is wheth...   Mar 28 2011, 05:26 PM
pcar916   Not a deal breaker. I like the both for different ...   Mar 28 2011, 05:57 PM
Britain Smith   I know this is an older thread...however several t...   Jul 1 2013, 11:04 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:20 PM
