| mgphoto |
Mar 27 2011, 11:30 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,431 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Hello,
I've had a problem with gasoline fumes coming into the cabin from the front trunk. I would fill the tank and sometimes forget and park the car at the curb, my street is pitched slightly from the center and slopes to the curbs, this makes the filler neck on the tank a few inches lower, this causes the fuel to run into the expansion tank. I wanted to replace the hose from the expansion tank as it has become brittle and cracked from age. I went to Bill and Steve's Superstore in Downey CA, to pick up a length of hose, ( they have thousands of VW parts ). I spoke with Robert, who know exactly what hose I was taking about, "your getting the fuel fumes inside the car right?" yes I said, and he said "that is because the fuel is running through the hose", he told me to solve that problem "all you have to do is make a loop in the hose, and have the top of the loop higher that the filler neck." See photos below. ![]() ![]() Brilliant, the fuel will not run though the hose and the fumes are gone. Just thought I would share this with the group. Mike |
| jaxdream |
Mar 28 2011, 07:16 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Having the right cap won't keep the fuel from sloshing / running up into that little hose , then into the expansion tank . But the loop in the hose with the loop above the fill level will , as mgphoto has already said it helped his problem . That's the reason there are P traps put into plumbing of houses , to keep the sewer vapor ( smell ) from coming back inside the house . Heck I like that idea , it's cheap , and seems to be effective .
My $.02 Jack / Jaxdream |
mgphoto Fuel vent hose Mar 27 2011, 11:30 PM
Tom_T If the fuel vapor control system's hoses are a... Mar 27 2011, 11:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 02:08 AM |
