> finally.... electrical short found. this is what it was..., for those of you who may have had elect. probs....
livinglobotomy
post Mar 28 2011, 10:58 AM
awhile ago i posted i was having electrical problems and could not solve this issue.... here is a refresh:
took the car in to get it painted and popped out all the lights etc. but kept track of the wiring. got the car back and put all the wires in and the left side blinkers would not work. tried to find the cause and traced it back to the switch at the steering column itself. replaced the switch and tested it before installing and it worked fine. then i installed it and tested it and all was good. then i mounted the steering wheel and all was good. next day the following happened.
"Symptoms: All lights work with the exception of the emergency flashers and right side turn indicators. ALL parking lights work (including right side.) All lights work appropriately when headlights are up or down (including right.)
When flasher is pulled, rapid clicking at relay occurs and turn signals and emergency flashers do not work. When right turn signal is on, rapid clicking at relay occurs and turn signals and flashers do not work. Pulling parking brake on or off has no effect on above.
Attempts: 1. All fuses were checked and replaced as a precaution. 2. All sockets were cleaned and all copper was pulled up for more positive seat on all bulbs. 3. All bulbs were replaced with all proper bulbs in proper places and checked and rechecked. 4. All wires to all lights were removed and reattached CORRECTLY per appropriate diagrams as seen on 914world AND pelican parts diagrams and checked and rechecked. 5. Reset button was pushed on master cylinder. 6. Two new relays were purchased (problem exists with either installed.) 7. Turn signal lever assembly was replaced at steering column. 8. Brake light switch at pedals was inspected and cleaned. 9. Parking brake switch was cleaned and inspected. No issues."
SGB
post Mar 28 2011, 11:23 AM
just visiting
Way to go Eastbay!
Thaks fer sharing...
- Lo-Fi Version Time is now: 30th April 2026 - 10:33 PM
