| Mueller |
Apr 6 2004, 11:27 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Since I don't want to be the laughing stock in the class I'll be placed in (QM I believe, Street Modified)
I figure I will have to step up to the plate and get a second set of rims and tires for auto-x (time trialing sooner or later...okay, much later) car has stock fenders, I do not want to add flares, but I am open to the idea of rolling the fenders or pulling/bumping them out slightly Current rims are 16x7 under stock fenders running 205/45/16's (40mm offset rims) |
| ninefourteener |
Apr 6 2004, 01:59 PM
Perfectly Normal Guy :) ![]() ![]() ![]() Group: Members Posts: 1,216 Joined: 3-June 03 From: St. Louis, MO Member No.: 779 |
If the 4X100 pattern is too close to the center hole...... isn't there another common 4-lug pattern??
I thought there was a 4X114 or something like that. Would that make enough difference?? |
Mueller 15",16",17" or ??? for auto-x rims/tires????? Apr 6 2004, 11:27 AM
ninefourteener There was a thread not too long ago about these gu... Apr 6 2004, 11:43 AM
Mueller thanks....too heavy and expensive for me !... Apr 6 2004, 11:49 AM
ninefourteener
anthony 205-50-15 sounds good. Don't people usually go... Apr 6 2004, 12:17 PM
Mueller I re-drilled and studded the rotors/hubs myself...... Apr 6 2004, 01:04 PM
Cloudbuster Scroll down to the Blast-C at
http://edgeracing.co... Apr 6 2004, 01:16 PM
Mueller hey Andy: :finger: :)
what is sad, is that I ... Apr 6 2004, 02:09 PM
Dave_Darling Running in Q-mod, you are gonna have an immensely ... Apr 6 2004, 05:41 PM
TimMartin Am i missing something? Class Qm is not a 914 clas... Apr 6 2004, 06:16 PM
nine14cats Hi Mike,
I'll chime in with what I've exp... Apr 6 2004, 06:34 PM
nine14cats Tim makes a good point. I believe that the modifi... Apr 6 2004, 06:37 PM
Mueller the turbo put's me into Qm.........unless I re... Apr 6 2004, 07:20 PM
campbellcj I think two big factors to consider are (a) do you... Apr 6 2004, 09:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th October 2026 - 04:17 PM |
