netbanshee |
Newbie ![]() Group: Members Posts: 26 Joined: 18-May 08 From: Philadelphia Member No.: 9,071 Region Association: North East States ![]() |
Hey everyone,
Been reading the forums for some years, but haven't had much to say up until now. So Hi, Hey and Hello. Nice to meet you. I'm looking for some feedback and/or recommendations on an issue my '70 914 1.7l is having. After replacing the flywheel seal a few times to no avail, my father and I are starting to look at a few other options and suggestions. Here's the car (upon delivery and there on): http://www.flickr.com/photos/netbanshee/27...in/set-1076179/ Regardless of what's been done so far, the car still manages to leak oil at about a drip every 1-2 seconds out of the bottom of the engine near the flywheel. The oil leak persisted after the car blew an oil galley plug behind the flywheel. Before the car decided to dump most of her oil out in the driveway, I was able to shut the car off and keep things from getting much worse. We proceeded to pull the engine and tranny, pull all of the galley plugs and threaded in some new ones. We also hit them up with JB Weld for added assurance. At this point we went ahead and gave the drivetrain and a good once over. We hadn't really pulled apart the car since I purchased it 3 years ago, so no better time then. The car was generally pretty solid up to that point since the owner kept the car in good shape and only put a few thousand miles on the car over the years after an extensive restoration. We checked the pressure release valves, replaced various gaskets, the fuel lines, relocated the fuel pump under the gas tank, fixed up the hell hole before it got away from us, etc., etc. We then went about replacing the flywheel seal and flywheel o-ring. The 3 shims were in good shape so got them cleaned and lubricated before putting them back in the way they were. We permatexed the outside of the flywheel seal, seated it, bolted everything back up and got the drivetrain back in the car. After starting the car, we started to get the oil leak I described. Since then, we have tried different flywheel seals (Elring Klinger at first, then Victor Reinz since) to no avail. We made sure that the end play on the crank was between .003 - .004mm and that we seated the seal flush with the case and in slightly different depths so it didn't ride in the previous spot. Also of note, the leak is definitely between the flywheel and the case. There isn't any foul smelling gear oil from the tranny to note. There isn't any indication that the galley plugs are anything but solid, so our thought was that there was an issue with the flywheel seal. Now that we've replaced it a few times, we're looking at other options. We were thinking that it might be time to replace the flywheel and bolts. The paperwork I have on the restoration suggests that the original flywheel was machined and polished (dual surface) and we did notice that the flywheel seal we initially removed (don't have it anymore) was white and nothing we had seen before. Possible the seal was a different type? So, what does everyone think? Any other ideas or suggestions beyond a new flywheel? Thanks, Sean (netbanshee) |
nathansnathan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None ![]() |
It sounds to me like the problem may be to do with the crankcase pressure - not oil pressure, but blow by/ pcv system. If there is too much pressure in the case, it will blow out the seals. i haven't solved my flywheel seal oil leak issue entirely but it helped a lot when I plumbed my breather box to my carb air cleaner tops.
914itis |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States ![]() |
It sounds to me like the problem may be to do with the crankcase pressure - not oil pressure, but blow by/ pcv system. If there is too much pressure in the case, it will blow out the seals. i haven't solved my flywheel seal oil leak issue entirely but it helped a lot when I plumbed my breather box to my carb air cleaner tops. I have a breather box from the crankcase breather ,then to my valve cover, the crankcase is vented thru my breather, then the oil goes back to the valve cover, I still have my leak after changing the seals. |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
It sounds to me like the problem may be to do with the crankcase pressure - not oil pressure, but blow by/ pcv system. If there is too much pressure in the case, it will blow out the seals. i haven't solved my flywheel seal oil leak issue entirely but it helped a lot when I plumbed my breather box to my carb air cleaner tops. I have a breather box from the crankcase breather ,then to my valve cover, the crankcase is vented thru my breather, then the oil goes back to the valve cover, I still have my leak after changing the seals. The heads AND the case vent to the breather, which is then vented to the air cleaner. The way you have it is way wrong. The Cap'n |
nathansnathan |
It sounds to me like the problem may be to do with the crankcase pressure - not oil pressure, but blow by/ pcv system. If there is too much pressure in the case, it will blow out the seals. i haven't solved my flywheel seal oil leak issue entirely but it helped a lot when I plumbed my breather box to my carb air cleaner tops. I have a breather box from the crankcase breather ,then to my valve cover, the crankcase is vented thru my breather, then the oil goes back to the valve cover, I still have my leak after changing the seals. The heads AND the case vent to the breather, which is then vented to the air cleaner. The way you have it is way wrong. The Cap'n With the breather box people usually get there are only 3 holes, so there's only 1 way it can be set up. It's supposed to flow out the tower, into the box, and then back to the heads, but I'm not sure that is what actually happens. Seems like just having that breather box would be 'wrong'. Empi is designed to destroy imo. |
Cap'n Krusty |
It sounds to me like the problem may be to do with the crankcase pressure - not oil pressure, but blow by/ pcv system. If there is too much pressure in the case, it will blow out the seals. i haven't solved my flywheel seal oil leak issue entirely but it helped a lot when I plumbed my breather box to my carb air cleaner tops. I have a breather box from the crankcase breather ,then to my valve cover, the crankcase is vented thru my breather, then the oil goes back to the valve cover, I still have my leak after changing the seals. The heads AND the case vent to the breather, which is then vented to the air cleaner. The way you have it is way wrong. The Cap'n With the breather box people usually get there are only 3 holes, so there's only 1 way it can be set up. It's supposed to flow out the tower, into the box, and then back to the heads, but I'm not sure that is what actually happens. Seems like just having that breather box would be 'wrong'. Empi is designed to destroy imo. That's just not true, and so is your last post. Not all 914 heads are vented. Early 1.7 heads aren't vented, nor are 1.8 heads and '75/'76 .0 heads. The purpose of a vent is to VENT. Putting the pressure and fumes back into the area from which they're taken is simply not venting. Late 356 and 912 engines vent to the intake (carburetor) as do the carbureted 911s. Why would you think the same would not be true for a carbureted 914? On open breather box of the type you see typically advertised for VW off road use is open to the air, and is illegal in the US. It's been that way since 1965. The Cap'n The Cap'n |
nathansnathan |
It sounds to me like the problem may be to do with the crankcase pressure - not oil pressure, but blow by/ pcv system. If there is too much pressure in the case, it will blow out the seals. i haven't solved my flywheel seal oil leak issue entirely but it helped a lot when I plumbed my breather box to my carb air cleaner tops. I have a breather box from the crankcase breather ,then to my valve cover, the crankcase is vented thru my breather, then the oil goes back to the valve cover, I still have my leak after changing the seals. The heads AND the case vent to the breather, which is then vented to the air cleaner. The way you have it is way wrong. The Cap'n With the breather box people usually get there are only 3 holes, so there's only 1 way it can be set up. It's supposed to flow out the tower, into the box, and then back to the heads, but I'm not sure that is what actually happens. Seems like just having that breather box would be 'wrong'. Empi is designed to destroy imo. That's just not true, and so is your last post. Not all 914 heads are vented. Early 1.7 heads aren't vented, nor are 1.8 heads and '75/'76 .0 heads. The purpose of a vent is to VENT. Putting the pressure and fumes back into the area from which they're taken is simply not venting. Late 356 and 912 engines vent to the intake (carburetor) as do the carbureted 911s. Why would you think the same would not be true for a carbureted 914? On open breather box of the type you see typically advertised for VW off road use is open to the air, and is illegal in the US. It's been that way since 1965. The Cap'n The Cap'n You're right, I guess they aren't all vented, 914 heads. I have 3 pairs of 1.7 heads that all have vents but they are from 72 and 73 models all. I guess earlier ones don't. Thanks for setting me straight on that. About the Empi breather, the cap on it doesn't seal so it does vent to the air. They're labelled 'off road use only" but I don't think it stops people. That said, even if you had no head vents, and hooked it to just the tower then the other 2 to the carb tops, you'd basically be drawing air (unfiltered) through the top of the breather box so that wouldn't work. My point was if the pcv system isn't hooked up to the intakes, but is just venting to the air, or worse, that it's all just sealed up, no head vents and especially if the tower breather is plugged, that could be the cause of the problem. Could be it's the tower breather itself that's the problem? A bus breather has just a baffle plate in there and flows right through where the 914 involves a diaphragm -could be choking things up/ introducing excessive pressure. |
Lo-Fi Version | Time is now: 8th July 2025 - 04:14 PM |
