| 76-914 |
Mar 24 2011, 11:41 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,920 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
While my drive train is out I decided to do some fuel upgrades. Once I had removed the tank to R&R hoses I decided to upgrade to the 75-76 style sans the 2 port pump. Why? Why spend the extra $$$, now. When this pump goes out I will change to the 2 port style which will require pulling the tank again, but so what. So now that the tank was out I ordered up a set of 8mm SS lines and required appurtanances from Rotary914. On a '73 the fuel lines are different sizes which makes it a little easier to slide on of the new 8mm lines into the grommets. Robert's video suggest 2 men to change these lines out but I had just myself. I found that by removing the shifter base bolts and turning the base 90 degrees I could push/pull the SS lines (one at a time) with a pair of vise grips with one hand while guiding the end thru the front grommet with the other hand. As Robert says in his video, "WD 40 is your friend".
![]() ![]() Next was to relo the fuel pump to avoid the vapor locking syndrome. I had asked around and heard both sides but figured this car may be in a hotter climate some day and I'll save the next owner a tow charge. Besides, it's one less fire starter in the engine bay. So as you all know, here was it's home beneath the battery (IMG:style_emoticons/default/lol-2.gif) and adjacent to the hottest burning cylinder and oil cooler (IMG:style_emoticons/default/av-943.gif) ![]() I wanted to locate the pump in the same place as my 76 but it wouldn't work out for me so I located it on the psg side. I was able to re-use the existing shock/vibration mounts. BTW, these are still available thru Aircraft Spruce. The blue tape was just a reference to the spare tire cover/lid so that it would be concealed and out of harms way. I will locate the filter beneath the tank (I know, I know) because I will be pulling the tank in 2 yr's to examine the hoses. As an experiment in longevity, I am using the new Goodyear hose in a side by side test with the German hose. e.g. 5/16" vs. 8mm on gravitational side and 1/4" vs. 7mm on the pressure side. ![]() And the backside. Notice the grommets. You could use some old larger sized hose for this, also. ![]() While I'm at it I will relo the vapor cannister but that's another thread. |
| silver74insocal |
Apr 5 2011, 04:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
is that a filter i see going under the tank? (IMG:style_emoticons/default/beer.gif) heres to hoping it dont crap out on you sir (IMG:style_emoticons/default/smile.gif)
76-914 Updating my '73's fuel system Mar 24 2011, 11:41 AM
Cairo94507 Nice and clean; I like the grommets too. Mar 24 2011, 05:52 PM
windforfun
:agre... Mar 24 2011, 05:59 PM
jeff9146 Nice job !
I am planing to do the same on my 6... Apr 5 2011, 03:38 PM
76-914 I felt ashamed when I saw how dirty that area was ... Apr 5 2011, 03:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 26th July 2026 - 01:58 AM |
