> l-jet on a 2.0 or 2056 advice needed
earlyaircooled
post Apr 5 2011, 09:21 PM
my 74, 2.0 came with a 1.8 engine complete with fuel injection. Dont know if it runs because it was out of the car when I bought it, was represented as 50,000 mile since rebuild and is clean and looks great. I have since picked up a correct 74. 2.0 engine, long block. I will either build a stockish 2.0 but I'm leaning towards a 2056 with Keith black pistons and Raby cam. Will the stock 1.8 l-jet work with the 2.0 or 2056 or would I be better off looking for a d-jet system? Does anyone have detailed info on this or a thread that they can point me to?
Thank you
dlee6204
post Apr 5 2011, 10:04 PM
Howdy
Root_Werks used l-jet on his 2.0L car....
http://www.914world.com/bbs2/index.php?sho...4990&st=100
Its a fairly straightforward swap.
silver74insocal
post Apr 5 2011, 11:55 PM
QUOTE(dlee6204 @ Apr 5 2011, 09:04 PM) *
Root_Werks used l-get on his 2.0L car....
(IMG:style_emoticons/default/agree.gif) use the search function, type in "2056" and click on "appears in title". read for a few hours...good stuff (IMG:style_emoticons/default/beerchug.gif)
earlyaircooled   l-jet on a 2.0 or 2056 advice needed   Apr 5 2011, 09:21 PM
Black22   :popcorn:   Apr 5 2011, 09:47 PM
G e o r g e   If you give jake all of the info he needs he will ...   Apr 5 2011, 09:57 PM
dlee6204   Root_Werks used l-jet on his 2.0L car.... http://...   Apr 5 2011, 10:04 PM
silver74insocal   Root_Werks used l-get on his 2.0L car.... http:/...   Apr 5 2011, 11:55 PM
Root_Werks   Root_Werks used l-get on his 2.0L car.... http:/...   Apr 6 2011, 09:23 AM
7275914911   The simple answer is Yes..... IIRC the 9550 cam wo...   Apr 6 2011, 06:57 AM
Cupomeat   L-Jet will work and with better drivability than t...   Apr 6 2011, 08:40 AM
Dave_Darling   If it were me, I would at least do one WOT run up ...   Apr 6 2011, 02:11 PM
Root_Werks   If it were me, I would at least do one WOT run up...   Apr 6 2011, 03:51 PM
r_towle   its a batch system and the injector flow rate is t...   Apr 6 2011, 02:33 PM
Drums66   ....I 've been running that combo since..... :...   Apr 6 2011, 03:06 PM
sean_v8_914   no speculation or hearsay... I have installed stoc...   Apr 6 2011, 04:15 PM
earlyaircooled   Thank you all who responded! I read the entire...   Apr 6 2011, 07:40 PM
Root_Werks   Thank you all who responded! I read the entir...   Apr 6 2011, 09:56 PM
earlyaircooled   Thank you all who responded! I read the enti...   Apr 6 2011, 10:30 PM
Al Meredith   I have a complete 912E Ljet system (for sale if an...   Apr 6 2011, 07:55 PM
kg6dxn   I have a pdf of the L Jetronic manual... PM me wit...   Apr 7 2011, 09:04 AM
sean_v8_914   912e also used the large square 2.0 plenum   Apr 7 2011, 09:06 AM
Cupomeat   As per the big Bosch FI manual, the flapper only c...   Apr 7 2011, 09:22 AM
Dave_Darling   Not even related to the throttle, just RPM. And t...   Apr 7 2011, 05:17 PM
Krieger   How about increasing the fuel pressure too? That ...   Apr 7 2011, 06:43 PM
- Lo-Fi Version Time is now: 11th July 2025 - 05:04 PM
