> Parasitic Battery Drain source found: Now what?
moneysmarts
post Apr 6 2011, 03:50 PM
Long-time- no-post!
Hi all.
Just took the car out of storage from winter, looking forward to driving.
My new battery keeps draining overnight.
So I tapped in-line my multimeter and started pulling fuses and relays to locate the source.
When I pulled the alternator wiring harness plug from the relay board, the volts/amps dropped to zero. Bingo!
But now what do I do? (IMG:style_emoticons/default/confused24.gif) Do I have a bad alternator or can I diagnose further?
Thanks for the help.
I'd hate to have to struggle to replace that bad boy for nothing.
Steve
moneysmarts
post Apr 7 2011, 02:09 PM
Rich:
I dropped the alt. off to Brian this morning at Chelmsford auto electric.
He just called me and said they cleaned it up, and replaced the bearings (for $65) but that the diodes were fine. They were not drawing any amps! (IMG:style_emoticons/default/blink.gif)
When I pick it up tomorrow, I'm gonna bring in my voltage regulator for him to test. But I'm reasonably sure that's not the parasite. (IMG:style_emoticons/default/WTF.gif)
messix
post Apr 7 2011, 02:18 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
QUOTE(moneysmarts @ Apr 7 2011, 01:09 PM) *
Rich:
how did they test this?
did they test each of the six diodes? or just check to see if it was producing a charge? it will still produce a charge if a couple of diode are shorted but will not provide full current charge. [amperage]
moneysmarts   Parasitic Battery Drain source found: Now what?   Apr 6 2011, 03:50 PM
r_towle   how far are you from Tyngsboro?   Apr 6 2011, 03:53 PM
moneysmarts   how far are you from Tyngsboro? I'm in Leom...   Apr 6 2011, 03:54 PM
messix   diode in the alt is blown and is energizing the fi...   Apr 6 2011, 03:54 PM
Root_Werks   Plug the alt harnes back in and the take the volt ...   Apr 6 2011, 03:54 PM
r_towle   unplug just the alternator at the alternator. It m...   Apr 6 2011, 03:55 PM
moneysmarts   unplug just the alternator at the alternator. It ...   Apr 6 2011, 03:59 PM
r_towle   not easily...but yes you can. Chelmsford Auto Ele...   Apr 6 2011, 04:01 PM
moneysmarts   [quote name='r_towle' date='Apr 6 2011...   Apr 6 2011, 04:09 PM
moneysmarts   I just pulled out the voltage regulator from the r...   Apr 6 2011, 04:07 PM
r_towle   well, that might seem easier, but it wont be in th...   Apr 6 2011, 04:11 PM
76-914   well, that might seem easier, but it wont be in t...   Apr 6 2011, 05:22 PM
SLITS   The alt harness unplugs from the relay board ........   Apr 6 2011, 05:24 PM
moneysmarts   The alt harness unplugs from the relay board .......   Apr 6 2011, 05:35 PM
moneysmarts   Rather than pulling apart the sheet metal to get a...   Apr 6 2011, 06:48 PM
messix   Rather than pulling apart the sheet metal to get ...   Apr 6 2011, 06:51 PM
moneysmarts   yes the diodes are blown and it needs to be rebuil...   Apr 6 2011, 07:05 PM
messix   yes the diodes are blown and it needs to be rebui...   Apr 6 2011, 07:15 PM
moneysmarts   OK Thanks much. I'll have to pull it out tomor...   Apr 6 2011, 07:20 PM
Root_Werks   Troy is my hero. :worship:   Apr 6 2011, 08:59 PM
Tom   I would agree with Troy's assesment also, but ...   Apr 7 2011, 12:58 PM
r_towle   in my recent experience with bosch rebuilt alterna...   Apr 7 2011, 01:54 PM
moneysmarts   Rich: I dropped the alt. off to Brian this morning...   Apr 7 2011, 02:09 PM
messix   Rich: I dropped the alt. off to Brian this mornin...   Apr 7 2011, 02:18 PM
moneysmarts   I have no idea Troy. When the guy called me and sa...   Apr 7 2011, 02:22 PM
messix   I have no idea Troy. When the guy called me and s...   Apr 7 2011, 02:33 PM
r_towle   troy, these guys are very good. This is all they d...   Apr 7 2011, 02:28 PM
messix   troy, these guys are very good. This is all they ...   Apr 7 2011, 02:34 PM
r_towle   OK, can someone post a diagram of that little wiri...   Apr 7 2011, 02:33 PM
moneysmarts   Rich: Just to refresh what I did... When I pulled ...   Apr 7 2011, 02:34 PM
r_towle   Rich: Just to refresh what I did... When I pulled...   Apr 7 2011, 02:41 PM
messix   Rich: Just to refresh what I did... When I pulle...   Apr 7 2011, 02:53 PM
moneysmarts   It looks ok, but I can replace it. Any special gau...   Apr 7 2011, 04:54 PM
messix   It looks ok, but I can replace it. Any special ga...   Apr 7 2011, 05:29 PM
moneysmarts   how are you testing for draw? where are you doing ...   Apr 7 2011, 06:51 PM
SLITS   Backup lights ... fuse 8 or 9? .... thru the main ...   Apr 7 2011, 04:57 PM
messix   Backup lights ... fuse 8 or 9? .... thru the main...   Apr 7 2011, 05:30 PM
SLITS   The question was "Where oh where does the bac...   Apr 7 2011, 05:34 PM
messix   so when you diconnect the wire from the alt to the...   Apr 7 2011, 06:56 PM
moneysmarts   Yup. Quirky. I'll put it all back together tom...   Apr 7 2011, 09:09 PM
Tom   I''l bet them cleaning it up cured your dr...   Apr 8 2011, 08:50 AM
TC 914-8   :popcorn: I'm curious what it is Keep us pos...   Apr 8 2011, 10:58 PM
moneysmarts   :popcorn: I'm curious what it is Keep us po...   Apr 9 2011, 02:34 PM
moneysmarts   :popcorn: I'm curious what it is Keep us p...   Apr 11 2011, 08:34 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:20 PM
