> Parasitic Battery Drain source found: Now what?
moneysmarts
post Apr 6 2011, 03:50 PM
Long-time- no-post!
Hi all.
Just took the car out of storage from winter, looking forward to driving.
My new battery keeps draining overnight.
So I tapped in-line my multimeter and started pulling fuses and relays to locate the source.
When I pulled the alternator wiring harness plug from the relay board, the volts/amps dropped to zero. Bingo!
But now what do I do? (IMG:style_emoticons/default/confused24.gif) Do I have a bad alternator or can I diagnose further?
Thanks for the help.
I'd hate to have to struggle to replace that bad boy for nothing.
Steve
moneysmarts
post Apr 7 2011, 02:34 PM
Rich:
Just to refresh what I did...
When I pulled the 3-wire alt. plug from the relay tray, my amp draw stopped.
The I reinserted the plug, and disconnected the hot wire from the alt (attached to the starter solonoid). That also made my amp draw go away.
Should I do some other tests?
r_towle
post Apr 7 2011, 02:41 PM
Custom Member
QUOTE(moneysmarts @ Apr 7 2011, 04:34 PM) *
Rich:
put it back in...unplug the lead at the starter solenoid.
Also, do you have the logic circuit (looks like a relay) under the passenger seat?
Two big yellow wires (yellow and yellow with red stripe)
And , where oh where does the reverse light switch get its power from?
Seems like it may be part of that hot lead...its in the same area.
Reverse light switch gets stuck...power draw....dunno.
Rich
messix
post Apr 7 2011, 02:53 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
QUOTE(r_towle @ Apr 7 2011, 01:41 PM) *
Rich:
Rich
reverse light is switched on the key on can't be that.
inspect the wire from the alt to the starter, could be damaged just bad enough to allow a small high resistance short, corrosion can cause high resistance shorts [draws] that when cleaned up resolve issues.
moneysmarts   Parasitic Battery Drain source found: Now what?   Apr 6 2011, 03:50 PM
r_towle   how far are you from Tyngsboro?   Apr 6 2011, 03:53 PM
moneysmarts   how far are you from Tyngsboro? I'm in Leom...   Apr 6 2011, 03:54 PM
messix   diode in the alt is blown and is energizing the fi...   Apr 6 2011, 03:54 PM
Root_Werks   Plug the alt harnes back in and the take the volt ...   Apr 6 2011, 03:54 PM
r_towle   unplug just the alternator at the alternator. It m...   Apr 6 2011, 03:55 PM
moneysmarts   unplug just the alternator at the alternator. It ...   Apr 6 2011, 03:59 PM
r_towle   not easily...but yes you can. Chelmsford Auto Ele...   Apr 6 2011, 04:01 PM
moneysmarts   [quote name='r_towle' date='Apr 6 2011...   Apr 6 2011, 04:09 PM
moneysmarts   I just pulled out the voltage regulator from the r...   Apr 6 2011, 04:07 PM
r_towle   well, that might seem easier, but it wont be in th...   Apr 6 2011, 04:11 PM
76-914   well, that might seem easier, but it wont be in t...   Apr 6 2011, 05:22 PM
SLITS   The alt harness unplugs from the relay board ........   Apr 6 2011, 05:24 PM
moneysmarts   The alt harness unplugs from the relay board .......   Apr 6 2011, 05:35 PM
moneysmarts   Rather than pulling apart the sheet metal to get a...   Apr 6 2011, 06:48 PM
messix   Rather than pulling apart the sheet metal to get ...   Apr 6 2011, 06:51 PM
moneysmarts   yes the diodes are blown and it needs to be rebuil...   Apr 6 2011, 07:05 PM
messix   yes the diodes are blown and it needs to be rebui...   Apr 6 2011, 07:15 PM
moneysmarts   OK Thanks much. I'll have to pull it out tomor...   Apr 6 2011, 07:20 PM
Root_Werks   Troy is my hero. :worship:   Apr 6 2011, 08:59 PM
Tom   I would agree with Troy's assesment also, but ...   Apr 7 2011, 12:58 PM
r_towle   in my recent experience with bosch rebuilt alterna...   Apr 7 2011, 01:54 PM
moneysmarts   Rich: I dropped the alt. off to Brian this morning...   Apr 7 2011, 02:09 PM
messix   Rich: I dropped the alt. off to Brian this mornin...   Apr 7 2011, 02:18 PM
moneysmarts   I have no idea Troy. When the guy called me and sa...   Apr 7 2011, 02:22 PM
messix   I have no idea Troy. When the guy called me and s...   Apr 7 2011, 02:33 PM
r_towle   troy, these guys are very good. This is all they d...   Apr 7 2011, 02:28 PM
messix   troy, these guys are very good. This is all they ...   Apr 7 2011, 02:34 PM
r_towle   OK, can someone post a diagram of that little wiri...   Apr 7 2011, 02:33 PM
moneysmarts   Rich: Just to refresh what I did... When I pulled ...   Apr 7 2011, 02:34 PM
r_towle   Rich: Just to refresh what I did... When I pulled...   Apr 7 2011, 02:41 PM
messix   Rich: Just to refresh what I did... When I pulle...   Apr 7 2011, 02:53 PM
moneysmarts   It looks ok, but I can replace it. Any special gau...   Apr 7 2011, 04:54 PM
messix   It looks ok, but I can replace it. Any special ga...   Apr 7 2011, 05:29 PM
moneysmarts   how are you testing for draw? where are you doing ...   Apr 7 2011, 06:51 PM
SLITS   Backup lights ... fuse 8 or 9? .... thru the main ...   Apr 7 2011, 04:57 PM
messix   Backup lights ... fuse 8 or 9? .... thru the main...   Apr 7 2011, 05:30 PM
SLITS   The question was "Where oh where does the bac...   Apr 7 2011, 05:34 PM
messix   so when you diconnect the wire from the alt to the...   Apr 7 2011, 06:56 PM
moneysmarts   Yup. Quirky. I'll put it all back together tom...   Apr 7 2011, 09:09 PM
Tom   I''l bet them cleaning it up cured your dr...   Apr 8 2011, 08:50 AM
TC 914-8   :popcorn: I'm curious what it is Keep us pos...   Apr 8 2011, 10:58 PM
moneysmarts   :popcorn: I'm curious what it is Keep us po...   Apr 9 2011, 02:34 PM
moneysmarts   :popcorn: I'm curious what it is Keep us p...   Apr 11 2011, 08:34 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:25 PM
