> EP, anyone?
groot
post Apr 6 2004, 03:36 PM
Dis member
So, there are some big changes coming in E-production (SCCA) to "equalize" the competition. In 2005, the 914-4 2.0L runs at 1870 pounds with driver.
Is anyone thinking of switching from FP to EP and using a 2.0L now that the 914 has lost 50 pounds?
As you may have guessed, I'm considering it. Since I have 2-2.0L engines and no 1.8s, I'll be starting in EP anyway. But, I'm on the 4-year plan to get competitive (IMG:style_emoticons/default/smilie_flagge24.gif) , so it really doesn't matter immediately.
I know they used to be competitive in EP.
Anyway, there have been some posts about the horsepower a FP 1.8 can make. Any thoughts on a 2.0L?
Brett W
post Apr 6 2004, 08:59 PM
I don't get the problem with the weakness of the 2.0 crank. Honda uses a 1.8 sized rod journal on an engine that turns to 9K, what makes it so much different? I know the Honda has a rod ratio that is much better/worse than what the 2.0 914 has.
A renowned T4 engine builder and 914 racer said the 2.0 was a lot tougher on bearings and needed to be counter weighted. He figured if you didn't run it more than about 7500 you could make it last pretty well but otherwise things could get expensive. I am not sure what the competetion's power levels look like but you would need probably 200-210 to be competetive and if they didn't change the carb sizes, you could be limited as far as power goes.
groot   EP, anyone?   Apr 6 2004, 03:36 PM
Jake Raby   I have actually made more power with teh FP spec e...   Apr 6 2004, 06:52 PM
d914
  Apr 6 2004, 08:42 PM
Brett W   I don't get the problem with the weakness of t...   Apr 6 2004, 08:59 PM
Jake Raby   I have seen MANY more spun bearing 2.0 engines tha...   Apr 6 2004, 09:20 PM
Brett W   Yeah I was planning on running a Honda rod journal...   Apr 6 2004, 10:47 PM
Jake Raby   Thats one of the bearings that I plan on running. ...   Apr 6 2004, 11:08 PM
campbellcj   Yikes, that's a wild class weight -- under 170...   Apr 6 2004, 11:13 PM
Brett W   Yeah the key to better engines is to use better te...   Apr 6 2004, 11:14 PM
Jake Raby   Once the rods are completed the lengthys are easy ...   Apr 7 2004, 12:03 AM
Brad Roberts   Kevin, I can think of 8-10 people who have done d...   Apr 7 2004, 12:58 AM
Brett W   Jake, I agree some engine will like a longer or sh...   Apr 7 2004, 02:42 AM
groot   Good feedback. Thanks. I will be running a 2.0L-4...   Apr 7 2004, 06:31 AM
Jake Raby   FYI, I'd be willing to cover alot of the R&D i...   Apr 7 2004, 07:48 AM
Brett W   Jake be careful about spreading yourself to thin. ...   Apr 7 2004, 10:51 AM
Jake Raby   Brett, Thanks for the concern.. Thats the whole r...   Apr 7 2004, 11:04 AM
Brett W   I agree, if I am not working I am wasting my life....   Apr 7 2004, 12:55 PM
Brad Roberts   Good thing the 3 of us dont live close together. I...   Apr 7 2004, 02:12 PM
groot   I'm up for it, no question!!! I...   Apr 7 2004, 06:23 PM
Jake Raby   Groot, That time line sounds perfect. PM me your n...   Apr 7 2004, 07:36 PM
Thorshammer   EP HUH?, 2.0 liter you say. T IV you think?. Last...   Apr 7 2004, 08:50 PM
Jake Raby   ...   Apr 7 2004, 10:06 PM
dinomium   I have a 73 road car and dream of racing it! I...   Apr 7 2004, 11:17 PM
Racer Chris   If given enough outside funding I would convert to...   Apr 8 2004, 05:16 AM
groot   Lots of great input!! Chris-I thought thi...   Apr 8 2004, 06:25 AM
synthesisdv   ...   Apr 8 2004, 07:00 AM
Bleyseng   Maybe we can convince the Fordahl's as they ha...   Apr 8 2004, 07:29 AM
Brett W   210 is do able but it will be very hard in Product...   Apr 8 2004, 07:42 AM
Thorshammer   I believe in what Jake says, Although I have never...   Apr 8 2004, 09:06 AM
groot   All very valid points. Thanks. I've been runn...   Apr 8 2004, 10:23 AM
Dave_Darling     Apr 8 2004, 07:11 PM
Thorshammer   HA! Just fond my conversation notes with Mike...   Apr 8 2004, 07:19 PM
Brett W   Yes Finch and I have talked on occasion and he has...   Apr 8 2004, 08:38 PM
Racer Chris     Apr 10 2004, 02:35 AM
Jake Raby   In the last few years alot of new things have been...   Apr 10 2004, 11:39 AM
groot   Somewhere buried in this thread someone asked abou...   Aug 16 2004, 02:34 PM
Jake Raby   We are smack dab in the middle of the engine build...   Aug 16 2004, 02:41 PM
groot   Jake, I'll be at my desk tomorrow. Give me a ...   Aug 16 2004, 06:06 PM
Jake Raby   Kevin, It is stock diameter.... Its is legal in ...   Aug 16 2004, 07:18 PM
Brad Roberts   Ha ha.. they only tear down the top 3 finishers (l...   Aug 16 2004, 07:53 PM
seanery   dont they do a randtom car from the top 10, too?   Aug 16 2004, 08:05 PM
groot   Stock diameter? Sweet, let's do it! Jake,...   Aug 17 2004, 06:19 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:57 PM
