| groot |
Apr 6 2004, 03:36 PM
Dis member ![]() ![]() ![]() Group: Members Posts: 897 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
So, there are some big changes coming in E-production (SCCA) to "equalize" the competition. In 2005, the 914-4 2.0L runs at 1870 pounds with driver.
Is anyone thinking of switching from FP to EP and using a 2.0L now that the 914 has lost 50 pounds? As you may have guessed, I'm considering it. Since I have 2-2.0L engines and no 1.8s, I'll be starting in EP anyway. But, I'm on the 4-year plan to get competitive (IMG:style_emoticons/default/smilie_flagge24.gif) , so it really doesn't matter immediately. I know they used to be competitive in EP. Anyway, there have been some posts about the horsepower a FP 1.8 can make. Any thoughts on a 2.0L? |
| Jake Raby |
Apr 6 2004, 11:08 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Thats one of the bearings that I plan on running. The 40mm journal will make it possible to also stuff bigger strokes in with less issues.
I already have Carrillo working on the rods, and when they are done and its all working I plan on having the design made into a standard H beam with a 22mm pin that can be bought for around 275 bucks.... I will be running these rods and journal in my 3.0 engine, I already have the crank made with the 40mm journals... The VW engineers were high when they made the rod 800 grams with a bolt that won't hold a 400 gram rod at any decent revs. No wonder the stock EFI shuts you down at 5500 like a switch.... I'm thinking that the Honda journal may be a huge key to even a better bottom end in the TIV engine, the crank maker thought I was high when I told them what I was running for a journal on that 86 stroke crank. The small journal will change the overlap on the crank, but the TIV crank is so tough that I tghink we'll be just fine... For a high revving shorter stroke engine it really would be sweet....and still even stronger. |
groot EP, anyone? Apr 6 2004, 03:36 PM
Jake Raby I have actually made more power with teh FP spec e... Apr 6 2004, 06:52 PM
d914
Brett W I don't get the problem with the weakness of t... Apr 6 2004, 08:59 PM
Jake Raby I have seen MANY more spun bearing 2.0 engines tha... Apr 6 2004, 09:20 PM
Brett W Yeah I was planning on running a Honda rod journal... Apr 6 2004, 10:47 PM
campbellcj Yikes, that's a wild class weight -- under 170... Apr 6 2004, 11:13 PM
Brett W Yeah the key to better engines is to use better te... Apr 6 2004, 11:14 PM
Jake Raby Once the rods are completed the lengthys are easy ... Apr 7 2004, 12:03 AM
Brad Roberts Kevin,
I can think of 8-10 people who have done d... Apr 7 2004, 12:58 AM
Brett W Jake, I agree some engine will like a longer or sh... Apr 7 2004, 02:42 AM
groot Good feedback. Thanks.
I will be running a 2.0L-4... Apr 7 2004, 06:31 AM
Jake Raby FYI,
I'd be willing to cover alot of the R&D i... Apr 7 2004, 07:48 AM
Brett W Jake be careful about spreading yourself to thin. ... Apr 7 2004, 10:51 AM
Jake Raby Brett,
Thanks for the concern..
Thats the whole r... Apr 7 2004, 11:04 AM
Brett W I agree, if I am not working I am wasting my life.... Apr 7 2004, 12:55 PM
Brad Roberts Good thing the 3 of us dont live close together. I... Apr 7 2004, 02:12 PM
groot I'm up for it, no question!!!
I... Apr 7 2004, 06:23 PM
Jake Raby Groot,
That time line sounds perfect. PM me your n... Apr 7 2004, 07:36 PM
Thorshammer EP HUH?, 2.0 liter you say. T IV you think?.
Last... Apr 7 2004, 08:50 PM
Jake Raby ... Apr 7 2004, 10:06 PM
dinomium I have a 73 road car and dream of racing it! I... Apr 7 2004, 11:17 PM
Racer Chris If given enough outside funding I would convert to... Apr 8 2004, 05:16 AM
groot Lots of great input!!
Chris-I thought thi... Apr 8 2004, 06:25 AM
synthesisdv ... Apr 8 2004, 07:00 AM
Bleyseng Maybe we can convince the Fordahl's as they ha... Apr 8 2004, 07:29 AM
Brett W 210 is do able but it will be very hard in Product... Apr 8 2004, 07:42 AM
Thorshammer I believe in what Jake says, Although I have never... Apr 8 2004, 09:06 AM
groot All very valid points. Thanks.
I've been runn... Apr 8 2004, 10:23 AM
Dave_Darling
Thorshammer HA!
Just fond my conversation notes with Mike... Apr 8 2004, 07:19 PM
Brett W Yes Finch and I have talked on occasion and he has... Apr 8 2004, 08:38 PM
Racer Chris
Jake Raby In the last few years alot of new things have been... Apr 10 2004, 11:39 AM
groot Somewhere buried in this thread someone asked abou... Aug 16 2004, 02:34 PM
Jake Raby We are smack dab in the middle of the engine build... Aug 16 2004, 02:41 PM
groot Jake,
I'll be at my desk tomorrow. Give me a ... Aug 16 2004, 06:06 PM
Jake Raby Kevin, It is stock diameter....
Its is legal in ... Aug 16 2004, 07:18 PM
Brad Roberts Ha ha.. they only tear down the top 3 finishers (l... Aug 16 2004, 07:53 PM
seanery dont they do a randtom car from the top 10, too? Aug 16 2004, 08:05 PM
groot Stock diameter? Sweet, let's do it!
Jake,... Aug 17 2004, 06:19 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:28 AM |
