> fan blade removal, what use
machina
post Apr 7 2004, 08:30 AM
Just separated the fan wheel from the big steel pulley ring. FYI, it takes the same 8mm 12pt bit that the CV uses. They were harder to get out than the CV bolts.
Anyway, I don't think I have a saw or airtool that will get in-between those blades. There is only like 6mm in between. Any suggestions?
TIA
dr
Mueller
post Apr 7 2004, 08:52 AM
914 Freak!
pliers or a screwdriver...the blades should break off near the bottom.....
synthesisdv   fan blade removal   Apr 7 2004, 08:30 AM
URY914   What are you trying to do? Remove some of the bla...   Apr 7 2004, 08:48 AM
Mueller   pliers or a screwdriver...the blades should break ...   Apr 7 2004, 08:52 AM
tat2dphreak   pardon my ignoragce(normal state)... but why remov...   Apr 7 2004, 08:55 AM
cha914   Lotsa racers do it so the engine will rev better.....   Apr 7 2004, 08:59 AM
tat2dphreak     Apr 7 2004, 09:02 AM
URY914   I removed some of my blades. I'll post a pic t...   Apr 7 2004, 09:02 AM
ArtechnikA
- Lo-Fi Version Time is now: 14th July 2025 - 02:48 AM
