| bfrymire |
Aug 25 2009, 01:28 AM
Salsaholic ![]() ![]() ![]() Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Hello everyone, This is my thread to cover my conversion from Carbs to EFI. I will be using the Bitzracing CIS to EFI conversion kit, to replace the webers on the motor now, which is a 2.7l six. (And before anyone asks, I am not selling the carbs, yet. (IMG:style_emoticons/default/smile.gif) Want to make sure it works better before I unload the carbs.) (http://www.bitzracing.com) Ok, I am sure someone will ask why. Well, I autocross the car every month, and drive sometimes on the street. The carbs, due to sitting, tend to gunk up and require regular maintenance, and because, I am hoping the car will idle better, and just in general be more well behaved street driving. (Hey, it may even polute less. One can hope.) First step is to take it and have it tested on the dyno for a benchmark before any changes. (http://www.dynospotracing.com) The kit is fairly complete with good instructions. (You have a few parts to source yourself, easy to get.) As I go, I will provide more part numbers and details. Here's a picture of the parts kit including parts I sourced myself. |
| plastex |
Feb 13 2011, 09:16 PM
Newbie ![]() Group: Members Posts: 15 Joined: 28-December 10 From: Akron, ohio Member No.: 12,533 Region Association: None |
http://www.bitzracing.com/gallery/Oscar_76...with_turbo.html
This was my old car that I did the EFI conversion. I fabricated the airbox, and used a mustang throttle body. I am doing this to my 1.8 liter later on this year. I have most of the parts. Oscar |
| bandjoey |
Feb 13 2011, 11:40 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
http://www.bitzracing.com/gallery/Oscar_76...with_turbo.html This was my old car that I did the EFI conversion. I fabricated the airbox, and used a mustang throttle body. I am doing this to my 1.8 liter later on this year. I have most of the parts. Oscar hi Oscar. Start a new thread for the 1.8 conversion. (IMG:style_emoticons/default/biggrin.gif) |
| bfrymire |
Mar 15 2011, 12:44 AM
Guys,
Finally sold the Alfa, and was able to clear out the garage. Spent a couple a weeks just cleaning and organizing! (Alfa was in there for over 5 years!) Anyway, Porsche content. Got the carbs off: ![]() And am fitting the CIS intake. This is just the trial fitting, and making sure how things will go in. You can see the new injectors installed. ![]() While I was in there, I saw more of the poor electrical wiring the PO did. (IMG:style_emoticons/default/sad.gif) More to cleanup. I am also a little disappointed in the fuel hoses and fittings. (Of course, it's all coming out for high pressure hoses.) By the way, the firewall has way too many drill holes in it! In a previous post, I showed the hole the PO made to get to the fan belt. (Covered by a plastic irrigation cover!) So, what's the best way to fill up all these small holes? Should make some fast progress now. I am also thinking about the IAC. Not sure if I want to use the stock unit, or a jeep unit. -- brett |
| bfrymire |
Apr 10 2011, 05:00 PM
Made some more progress. Still going way too slow.
Runners, injectors and most of the fuel system installed. ![]() Here's the air intake. You can see the mounting of the IAT. Still fussing with this a little. The cone filter has not arrived yet. ![]() Finally, the mounting of the ECU into the passenger compartment. The MS can not be mounted into the engine bay due to heat concerns. I will be drilling an access hole right below it for the harness. ![]() What's next? 1. Fuel system complete: Mount fuel pump Route fuel lines Attach fuel filter Wire relay 2. Still need adapters for the different line sizes. I will be contacting tangerine on Monday to order the bits and pieces. 3. Need to mount the engine temp sensor 4. Finish attaching the harness to the injectors 5. Splice into wiring harness for power for ECU and wiring the sensors 6. Attach linkage to tb 7. And finally, weld the O2 sensor bung into the left header. I am sure I am missing something. Will update more soon. I am trying to get an initial fire of the engine next weekend. (IMG:style_emoticons/default/smile.gif) -- brett |
| bfrymire |
Apr 11 2011, 02:41 PM
bfrymire Conversion from Carbs to CIS to EFI Aug 25 2009, 01:28 AM
Dr Evil Thanks for chronicling this :) I am interested. Aug 25 2009, 01:44 AM
bfrymire
... Aug 25 2009, 02:14 AM
shoguneagle Agree with the "Good Doc Evil". very in... Aug 25 2009, 02:12 AM
bfrymire
Agree with the "Good Doc Evil". very i... Aug 25 2009, 02:17 AM
Gint Cool! What do you plan to use for induction, ... Aug 25 2009, 08:04 AM
bfrymire
Cool! What do you plan to use for induction,... Aug 25 2009, 02:12 PM
wobbletop Subscribed. :D Aug 25 2009, 01:36 PM
turboman808 Why can't webers be converted to fuel injectio... Aug 25 2009, 01:57 PM
bfrymire
Why can't webers be converted to fuel injecti... Aug 25 2009, 02:16 PM
GeorgeRud Yes, please continue to chronicle your progress. ... Aug 25 2009, 02:23 PM
bfrymire
Yes, please continue to chronicle your progress. ... Aug 25 2009, 04:08 PM
turboman808 I was gonna say mount em like this but I think the... Aug 25 2009, 03:13 PM
bfrymire
I was gonna say mount em like this but I think th... Aug 26 2009, 02:15 AM
r_towle
I was gonna say mount em like this but I think th... Nov 17 2009, 10:30 PM
bfrymire Ok. Here's a picture in a 911 of what the fi... Aug 26 2009, 02:18 AM
number6 For those who didn't catch it, there was an Ex... Aug 26 2009, 03:25 AM
shoguneagle Would appreciate at least the date of the issue an... Aug 26 2009, 09:58 AM
wobbletop Could it be...
#167 Sep 2008
How to Add EFI to Yo... Aug 26 2009, 11:13 AM
bfrymire Status update:
Went and did the Dyno thing today.... Sep 4 2009, 11:10 PM
rktmn247 Progress? Very interested in this. Thanks for ta... Sep 16 2009, 10:51 PM
bfrymire
Progress? Very interested in this. Thanks for t... Sep 17 2009, 09:02 PM
bfrymire I am going to also post a bill of materials includ... Sep 17 2009, 09:02 PM
bfrymire I'm back....
Finally got some time to work on... Nov 17 2009, 01:06 AM
Mark Henry Very interesting!
Can I ask the size of the T... Nov 17 2009, 06:01 AM
bfrymire
Very interesting!
Can I ask the size of the ... Nov 17 2009, 08:29 PM
bfrymire Hello Guys,
Made some more progress. This conver... Nov 25 2009, 11:13 PM
Mark Henry I won't ask for his base maps:) Nov 17 2009, 10:26 PM
rktmn247 Next update please! :poke: Mar 5 2010, 08:47 PM
bfrymire
I was missing ... Mar 6 2010, 01:30 AM
rktmn247 You're welcome. Looking forward to the pics. Mar 6 2010, 01:55 AM
bfrymire
Still making slow progress. Here's the cutu... Mar 6 2010, 09:57 PM
pete-stevers interesting thread....
keep up the good work Mar 7 2010, 12:56 AM
Dr Evil This is great. Thanks for keeping us up to date :)... Mar 7 2010, 01:02 AM
rfuerst911sc Why do you think you have to install a pop-off val... Mar 7 2010, 05:54 AM
Al Meredith Rather than use Webers for Throtte Bodies why not ... Mar 7 2010, 12:08 PM
bfrymire
Made some more progress today. (Still need to... Mar 7 2010, 08:29 PM
rktmn247 Bump! Finished? :poke: Feb 12 2011, 07:53 PM
bfrymire You must be a mind reader! Amazing. I was go... Feb 13 2011, 01:31 AM
rktmn247 Looking forward to your update. Really want to se... Feb 13 2011, 03:02 AM
Gint :agree: Me too! Thanks for the bump. Feb 13 2011, 09:28 AM
sixnotfour Finally a 914 using this ,
MK was making these alu... Feb 13 2011, 09:46 AM
bfrymire
MK was making these al... Feb 13 2011, 01:00 PM
sixnotfour
MK was making these a... Feb 13 2011, 01:22 PM
bfrymire
[quote name='bfrymire' post='1430913' date='Feb 1... Feb 13 2011, 03:34 PM
GeorgeRud It's nice to see more information on this conv... Feb 13 2011, 01:40 PM
rktmn247
http://www.bitzracing.com/gallery/Oscar_76...with... Feb 13 2011, 10:22 PM
bfrymire
http://www.bitzracing.com/gallery/Oscar_76...with... Feb 13 2011, 10:28 PM
rktmn247 I love this thread. I am getting so many ideas. ... Feb 13 2011, 10:31 PM
JmuRiz Very cool stuff, can't wait to hear your impre... Apr 11 2011, 02:53 PM
bfrymire
Very cool stuff, can't wait to hear your impr... Apr 11 2011, 04:23 PM
Dr Evil My 2.7 with CIS was nice. I almost had it dialed i... Apr 11 2011, 10:40 PM
bfrymire
My 2.7 with CIS was nice. I almost had it dialed ... Apr 12 2011, 12:03 AM
Fair amount of progress.
Most of ... Apr 18 2011, 08:28 PM
rick 918-S
Status update:
Most of... Apr 18 2011, 08:52 PM
bfrymire
Nice work, I have CIS. I used a Volvo turbo pump... Apr 18 2011, 09:58 PM
ArtechnikA
...I did not put an accumulator in. ... I under... Jun 23 2011, 05:06 AM
bfrymire
...I did not put an accumulator in. ... I unde... Jun 23 2011, 01:20 PM
TROJANMAN I didn't read through the entire thread, so I ... Apr 18 2011, 11:40 PM
bfrymire
I didn't read through the entire thread, so I... Apr 19 2011, 12:36 AM
Dr Evil Can you not rotate the throttle body to match the ... Apr 19 2011, 05:35 AM
bfrymire
Can you not rotate the throttle body to match the... Apr 19 2011, 12:27 PM
Dr Evil It is possible I am not getting it :)
Here is wha... Apr 19 2011, 12:33 PM
bfrymire
Here is wh... Apr 19 2011, 02:33 PM
Dr Evil
Here is w... Apr 19 2011, 02:49 PM
Almost ready to fire. Finished a... May 2 2011, 01:13 AM
Randal Looks like your build is progressing nicely. Good... Apr 19 2011, 01:14 PM
bfrymire
Looks like your build is progressing nicely. Goo... Apr 19 2011, 02:31 PM
rktmn247 Does it run? Did you make it to the auto x? :b... Jun 23 2011, 02:13 AM
bfrymire
Does it run? Did you make it to the auto x? :... Jun 23 2011, 01:19 PM
Series9 The two-year anniversary is rapidly approaching on... Jun 23 2011, 05:44 AM
bfrymire
The two-year anniversary is rapidly approaching o... Jun 23 2011, 01:21 PM
bfrymire Minor update. Fixed a few issues, and got the lin... Sep 10 2011, 08:25 PM
bfrymire Video.
Not sure how to do the imbedded vids: he... Sep 11 2011, 12:48 AM
GeorgeRud Sounds great! Can't wait to see the final... Sep 11 2011, 07:24 AM
Dr Evil :)
ReS1KjpH7oU Sep 12 2011, 06:27 PM
bfrymire Thanks. You will need to teach me. I have more vi... Sep 12 2011, 08:59 PM
Gint Sweet.
You just need to use the youtube tags with... Sep 13 2011, 09:02 PM
rktmn247 Great job seeing this through! Keep us posted... Sep 14 2011, 01:52 AM
bfrymire Just got back from an autocross. First one with t... Sep 18 2011, 03:10 PM
Jeffs9146 Can you give me some info on the wireing of your o... Sep 21 2011, 12:13 PM
bfrymire
Can you give me some info on the wireing of your ... Sep 21 2011, 01:19 PM
bfrymire
Can you give me some info on the wireing of your ... Sep 22 2011, 12:01 AM
Jeffs9146 :beer2:
Anything would help!
Are you going ... Sep 21 2011, 02:40 PM
bfrymire
:beer2:
Are you going... Sep 21 2011, 05:08 PM
Jeffs9146 That seems to be my problem.....nothing is matchin... Sep 22 2011, 01:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:52 PM |
