Rear 5-lug Conversion, Gauging Interest... |
Eric_Shea |
Apr 8 2004, 07:06 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Hi Gang,
While the front suspension seems to be a breeze (bolt on a 911 set-up), I was wondering if anyone would be interested in a turn key (bolt them on) rear conversion? Kit would contain: 2 Control Arms - Bead blasted to bare metal. Checked for straightness. Repainted with POR-15. 2 New Wheel Bearings 2 Rebossed and drilled 5-lug Hubs. Factory 45mm Studs. Set in the new wheel bearings. I was thinking $450 plus your loaded/usable control arms as cores (control arms and hubs). So for $450 you have basically "brand new" control arms, bearings and 5-lug hubs ready to go. You'd have to buy 914-6 rotors. Doable? Anything I'm missing? You could add items at will (Mueller bearings, Box kits etc...). Thoughts? |
Eric_Shea |
Apr 8 2004, 07:24 PM
QUOTE would you be interested in being an installer of front and rear bearing kits? Sure... it basically depends on the interest I get. I'm not looking at mass production but after going through it a few times I have contacts to do these things right (bead blasting, qualified machine shop, etc...) and a full array of tools here. Thinking it over over a Woodfords Reserve in the rocks... |
Lo-Fi Version | Time is now: 8th June 2024 - 03:20 PM |
