Rear brake pads for /6 - same as /4? |
smontanaro |
Apr 23 2011, 04:05 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
I need some rear pads for my /6. Are they the same as the /4? I was having a little trouble figuring that out on AA and Pelican sites, though I suspect they are the same.
Thx, Skip |
Eric_Shea |
Apr 23 2011, 09:19 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Almost all pads need to have the holes drilled out by now. Most companies don't make 914 4 or 6 rear pads anymore (with the larger holes on one side)
914-6 rear pads are the same as the following pads: Early 914-4 Fronts Early 911 Fronts (with M-Calipers through 76) Early 911 Rears (with rear M-Calipers through 83) These pads are as common as the calipers they came in so they should be a dime a dozen. Most european sedans had M-Calipers on them at one time or another so they should be easy to find. 914-4 and 914-6 rear calipers are very different. While most wouldn't notice this in a picture you can tell by a few visual clues and the following: * Pistons - 33mm for the 914-4 caliper and 38mm for the 914-6 (same as most 911 rear pistons) * Pads - Smaller AP30 pad for the 914-4 (same as very early 911's and 912's) and AP31 for the 914-6 (again, same as most 911's through 1983) * Larger overall bodies. The nose section of a 914-6 caliper is the same as the 911 rear M-Caliper. * No casting ridge on the inner caliper 1/2 spine. 914-6 calipers have a smooth spine on the back 1/2 of the caliper. 914-4 calipers have a raised ridge along the spine of the inner 1/2. I realize that's probably TMI but theres probably a lot of people that would like to know the differences between the two calipers. |
Tom_T |
Apr 24 2011, 08:57 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Almost all pads need to have the holes drilled out by now. Most companies don't make 914 4 or 6 rear pads anymore (with the larger holes on one side) 914-6 rear pads are the same as the following pads: Early 914-4 Fronts Early 911 Fronts (with M-Calipers through 76) Early 911 Rears (with rear M-Calipers through 83) These pads are as common as the calipers they came in so they should be a dime a dozen. Most european sedans had M-Calipers on them at one time or another so they should be easy to find. 914-4 and 914-6 rear calipers are very different. While most wouldn't notice this in a picture you can tell by a few visual clues and the following: * Pistons - 33mm for the 914-4 caliper and 38mm for the 914-6 (same as most 911 rear pistons) * Pads - Smaller AP30 pad for the 914-4 (same as very early 911's and 912's) and AP31 for the 914-6 (again, same as most 911's through 1983) * Larger overall bodies. The nose section of a 914-6 caliper is the same as the 911 rear M-Caliper. * No casting ridge on the inner caliper 1/2 spine. 914-6 calipers have a smooth spine on the back 1/2 of the caliper. 914-4 calipers have a raised ridge along the spine of the inner 1/2. I realize that's probably TMI but theres probably a lot of people that would like to know the differences between the two calipers. Eric is also far too modest. Contact him/PMB for the proper pads in Porterfield R4S (#??) pads F & R on that beautiful metallic blue 6 Skip! (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 08:59 PM |
