Wiring Help Please, Fuel Pump won't shut off |
rwilner |
Apr 23 2011, 09:54 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
My reverse lights weren't coming on. I traced it back to my ignition harness, which was totally hacked up. The yellow ignition wire was butt-spliced AROUND the relay board. The reverse light wires were run as completely separate wires. The pinout of the 12-pin connector on the aft side of the relay board was completely wrong. DAPOs strike again! I have no idea how this car even started and ran in this condition, but it did.
So I got a rebuilt relay board and a decent ignition harness from Mark Heard. I took the good part of my harness and the good part of his, and combined them. I rung out the harness with my dmm -- all good. I transfer the vreg and relays over to the new board, install, run the new harness. I turn the key to ACC and put the car in reverse. The reverse lights come on for the first time since I owned the car! Yes! But wait...the fuel pump seems to keep running. Before my repair, when I turned the key to ACC and left it, the fuel pump would run for a second or 2 and then stop. So I try to start it, and it's running really rough. It starts to make a wheezing sound after maybe 5 seconds, and I shut it off. I know this isn't a ton of info, but do you guys have any ideas? 73 2.0L FI, crane electronic ignition and coil. Moving in the right direction....I will undo all the sins of the past Thanks Rich Pics of the harness I removed are below (IMG:style_emoticons/default/barf.gif) |
Tom_T |
Apr 24 2011, 08:49 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Rich, IMHO after 38 years of frying in the hot engine bay, those harnesses need rebuilt or replaced anyway - unless you enjoy driving yourself (IMG:style_emoticons/default/wacko.gif) chasing electrical gremlins ad nauseum. (IMG:style_emoticons/default/biggrin.gif)
FYI Jeff Bowlsby sells rebuilt ones, & I think he rebuilds the relay boards too, as well as selling repro intermittent wiper harness/relay if you want to add that feature (install & snap out retent tab on steering column housing & you've got intermittent option). http://bowlsby.net/914/WiringHarnesses/ |
rwilner |
Apr 24 2011, 08:53 AM
Tom
No question -- Jeff's ignition harness is on my list, and my experiences last night may bring it up a notch or 2! I'm replacing all the FI stuff with megasquirt soon so I don't think investing in an FI harness is worth it for me. Put some bucks into the trans and a carpet set so trying to get by for awhile with what I have and enjoy the car at some DE events. 70 degrees and sunny outside right now -- having the car out of commission is killing me! Ok I'm going to stop typing and start troubleshooting. |
rwilner |
Apr 24 2011, 10:24 AM
OK, here's some pics.
Here's my "new" relay board and repaired harnesses, as installed: Here's a photo of the "new" 12-pin connector. The pinout matches the bowlsby drawing and Haynes: Here's a photo of the "old" 12 pin connector. Nothing is in the right spot except for the AAR wire and the green jumper. The red and black wires on the left were going to my reverse switch, which, shockingly, didn't work! That's what started this whole exercise Here are the two pinouts compared: I checked, and the black/purple stripe is connected to coil -, and the thicker black one is connected to coil +. Pic in the next post. |
rwilner |
Apr 24 2011, 10:28 AM
Here's a picture of my ignition setup. This is not my installation work. Looking at the crane manual, the - and + are hooked up correctly -- at least, the blk/purple stripe is connected to the right spot.
The wiring in the upper left goes to an MSD rev limiter (Again, not my install). This whole setup worked ok before I dug into the hacked up harness to fix my reverse lights. At this point i'm thinking the PO or PO's mechanic swapped the 14 pin connector's pinout at the front of the board to match the screwed up pinout of the 12 pin connector at the rear. Does anyone know what the pinout is for the 14 pin connector (near the firewall)? I have haynes but if someone has a drawing or another source, much appreciated. Any other ideas? |
Lo-Fi Version | Time is now: 10th June 2024 - 08:38 AM |
