Rear 5-lug Conversion, Gauging Interest... |
Eric_Shea |
Apr 8 2004, 07:06 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Hi Gang,
While the front suspension seems to be a breeze (bolt on a 911 set-up), I was wondering if anyone would be interested in a turn key (bolt them on) rear conversion? Kit would contain: 2 Control Arms - Bead blasted to bare metal. Checked for straightness. Repainted with POR-15. 2 New Wheel Bearings 2 Rebossed and drilled 5-lug Hubs. Factory 45mm Studs. Set in the new wheel bearings. I was thinking $450 plus your loaded/usable control arms as cores (control arms and hubs). So for $450 you have basically "brand new" control arms, bearings and 5-lug hubs ready to go. You'd have to buy 914-6 rotors. Doable? Anything I'm missing? You could add items at will (Mueller bearings, Box kits etc...). Thoughts? |
jonwatts |
Apr 8 2004, 11:09 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
QUOTE(Mueller @ Apr 8 2004, 08:59 PM) for steel parts, I've left them in cleaner for a few weeks with no problem Yeah, you got lucky on that one. I've been using the Super Clean to get the grime and overspray from a bad paint job off my wiring harness. I'm using it with fine steel wool and it's working good. I'm holding final judgement for when I see it in a real degreasing situation, though not much stacks up well to aerosol brake cleaner. |
Lo-Fi Version | Time is now: 8th June 2024 - 07:12 AM |
