> Weber problem
stock93
post Apr 5 2004, 08:17 PM
I have a 2.0 type IV engine with 44idfs on it. I was going to sync the carbs today and noticed that even when not pumping the throttle the accelerator pump drips a stream of gas down into the throat of the carb enough that its pooling up a bit on the throttle plate. I'm getting popping back through the carbs. Timing is spot on and the valves are correctly adjusted. I take it this is a problem and they arent supposted to do this? It also smells like its still running to rich. I have 135 mains, 200 airs, 55 idles, 36mm vents, and no velocity stacks currently. Mixture screws are set 1.5 turns out. Its also hesitating from idle to around 3K rpm if I step on it hard like its flooding out. Time to put kits in the carbs? Does the jetting for the accelerator pump need to be changed or adjusted?
John
apoplexy
post Apr 9 2004, 01:01 PM
eh?
QUOTE(SirAndy @ Apr 8 2004, 09:48 PM)
haven't seen you in quite a while!
Andy
Hey Andy!
Yeah, I've been MIA for a while, pissed at my car. (IMG:style_emoticons/default/headbang.gif) Hopefully these guys can figure out what the deal is so I can go road-tripping this summer!
Carrie
- Lo-Fi Version Time is now: 4th July 2025 - 07:19 AM
