Heater Blower Motor Mounting, Mine seems to be constant ground due to mounting... |
ptravnic |
Apr 27 2011, 03:05 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
Hi all,
I have a 72 which does not have the nice U shaped blower motor mount in the engine compartment that the later years have. I'm operating under the impression that this bracket is the early stock mount for the motor assembly: However, since the ground is supposed to be intermittent (actuates when the red cockpit lever is pulled up all the way) I have the problem where, because the above pictured mount grounds the entire assembly, I'm always grounded causing the blower to start up as soon as I turn on the ignition. I've tested my ground/red lever as the actuator when the motor assembly is not mounted (thus not automatically grounded) and it works like its supposed to - lever goes up and the motor turns on. Is there a way to separate the actual motor from the assembly so that it is not grounded when mounted? Maybe the rubber piece in the first pic goes somewhere that I'm obviously missing? Is there another way to mount the motor assembly that I just don't know of? (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/hissyfit.gif) Thanks in advance! -pt ps - cross posted from the Club site. I'm staying out of the turf wars b/c I like folks on both boards... (IMG:style_emoticons/default/grouphug.gif) |
SirAndy |
Apr 29 2011, 01:00 PM
Resident German Group: Admin Posts: 41,682 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Pin 11, green wire, going to (65) which is the heater blower. Ground should go to the chassis somewhere.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.pelicanparts.com-179-1304103637.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.pelicanparts.com-179-1304103702.1.jpg) |
ptravnic |
Apr 29 2011, 01:14 PM
Pin 11, green wire, going to (65) which is the heater blower. Ground should go to the chassis somewhere. Andy, you are the man. See, it turns out that I just have a green jumper cable from one side of the loom to the other... No green wire heading out of the board! I wonder what that jumper cable was intended for? |
SirAndy |
Apr 29 2011, 02:19 PM
I wonder what that jumper cable was intended for? I forget, but the jumper is supposed to be there (late only?) ... (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 12th June 2024 - 01:13 AM |
