| cdadaa |
Oct 24 2010, 10:37 AM
Newbie ![]() Group: Members Posts: 6 Joined: 25-May 09 From: Spring Creek, Nevada Member No.: 10,402 Region Association: None |
Hi,
Is this the correct positioning for the cooling flaps with a cold unexpanded bellows? Somehow I think the rod may have been bent or the flaps twisted by the previous owner. I want to hook up the thermostat so I can have a wintertime heater. Thanks...Dan Attached thumbnail(s) |
| ziggy |
May 9 2011, 08:25 PM
Newbie ![]() Group: Members Posts: 19 Joined: 2-May 11 From: Austin, TX Member No.: 13,013 Region Association: Southwest Region |
Were the cable running to the thermo to break, would the flaps default to the full hot position? I'm in Texas and running hot and noticed that little arm doesn't ever move as far as it is in his picture above. (the hot position photo)
cdadaa Cooling Flaps Oct 24 2010, 10:37 AM
Sleepin That is the hot position IIRC. Oct 24 2010, 11:07 AM
StratPlayer Thermostat cable connects with the connector in th... Oct 24 2010, 11:11 AM
cdadaa So the flaps are both "up" or closed lik... Oct 24 2010, 11:21 AM
Cap'n Krusty The system in question has ABSOLUTELY NOTHING to d... Oct 24 2010, 11:53 AM
cdadaa That wasn't my question Mr. Cap'n! Oct 24 2010, 12:04 PM
Cap'n Krusty
... Oct 24 2010, 03:37 PM
Jake Raby In the HOT position the diverter over the oil cool... Oct 24 2010, 12:56 PM
abayer1969 :popcorn: Oct 24 2010, 03:39 PM
cdadaa Thanks Jake...that makes sense. I'm good to g... Oct 24 2010, 05:31 PM
gasman Looks like you have the heads on the wrong sides..... Oct 24 2010, 05:41 PM
cdadaa Look again...I believe the CHT is on the passenger... Oct 24 2010, 05:53 PM
SirAndy BTW, this is going in a 912E.
And we knew that bec... May 9 2011, 09:14 PM
jaxdream
Look again...I believe the CHT is on the passenge... May 10 2011, 07:33 AM
McMark ONLY attach the wire with the flaps in this positi... May 10 2011, 12:00 AM
914Mike
ONLY attach the wire with the flaps in this posit... May 10 2011, 01:20 AM
vsg914
Looks like you have the heads on the wrong sides.... May 10 2011, 08:18 AM
sean_v8_914 Jake was being subtle. write it on a calendar and ... May 10 2011, 09:33 AM
McMark
Jake was being subtle. write it on a calendar and... May 10 2011, 10:43 AM
914Mike
Jake was being subtle. write it on a calendar an... May 10 2011, 11:34 AM
McMark
True, but it would be 'when the bellows are _... May 10 2011, 06:04 PM
enderw88
True, but it would be 'when the bellows [i]a... May 10 2011, 07:19 PM
McMark I don't like it. I decree my interpretation t... May 10 2011, 07:30 PM
enderw88
I don't like it. I decree my interpretation ... May 10 2011, 08:04 PM
sean_v8_914 gramar police should has at least 200 posts to qua... May 11 2011, 08:01 AM
914Mike
Grammar police should have at least 200 posts to ... May 13 2011, 01:28 AM
jaxdream phuch em , make hims dos a tyme aught &&... May 11 2011, 08:05 AM
MikeM Just to be clear....I'm missing some parts fro... May 12 2011, 07:38 AM
vsg914 Mike, the default is to the hot in case the cable ... May 12 2011, 09:33 AM
Mike, the default is to the hot in case the cable... May 12 2011, 10:55 AM
Root_Werks I see three major points that have been made to th... May 12 2011, 12:17 PM
MikeM Thanks guys...if I would have thought about that f... May 12 2011, 07:51 PM
avidfanjpl Mike,
On the standard temp gauge in the console i... May 12 2011, 09:24 PM
914Mike
On a cold motor, flap bolt tiedown should be... May 13 2011, 01:11 AM
avidfanjpl Everyone has an opinion based on experience on the... May 13 2011, 01:29 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th September 2026 - 12:08 PM |
