| cdadaa |
Oct 24 2010, 10:37 AM
Newbie ![]() Group: Members Posts: 6 Joined: 25-May 09 From: Spring Creek, Nevada Member No.: 10,402 Region Association: None |
Hi,
Is this the correct positioning for the cooling flaps with a cold unexpanded bellows? Somehow I think the rod may have been bent or the flaps twisted by the previous owner. I want to hook up the thermostat so I can have a wintertime heater. Thanks...Dan Attached thumbnail(s) |
| cdadaa |
Oct 24 2010, 05:53 PM
Look again...I believe the CHT is on the passenger side. The photo was taken from the flywheel (engine rear, front of car) side. BTW, this is going in a 912E.
| SirAndy |
May 9 2011, 09:14 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,523 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
BTW, this is going in a 912E. And we knew that because .... ? (IMG:style_emoticons/default/confused24.gif) |
cdadaa Cooling Flaps Oct 24 2010, 10:37 AM
Sleepin That is the hot position IIRC. Oct 24 2010, 11:07 AM
StratPlayer Thermostat cable connects with the connector in th... Oct 24 2010, 11:11 AM
cdadaa So the flaps are both "up" or closed lik... Oct 24 2010, 11:21 AM
Cap'n Krusty The system in question has ABSOLUTELY NOTHING to d... Oct 24 2010, 11:53 AM
cdadaa That wasn't my question Mr. Cap'n! Oct 24 2010, 12:04 PM
Cap'n Krusty
... Oct 24 2010, 03:37 PM
Jake Raby In the HOT position the diverter over the oil cool... Oct 24 2010, 12:56 PM
abayer1969 :popcorn: Oct 24 2010, 03:39 PM
cdadaa Thanks Jake...that makes sense. I'm good to g... Oct 24 2010, 05:31 PM
gasman Looks like you have the heads on the wrong sides..... Oct 24 2010, 05:41 PM
jaxdream
Look again...I believe the CHT is on the passenge... May 10 2011, 07:33 AM
ziggy Were the cable running to the thermo to break, wou... May 9 2011, 08:25 PM
McMark ONLY attach the wire with the flaps in this positi... May 10 2011, 12:00 AM
914Mike
ONLY attach the wire with the flaps in this posit... May 10 2011, 01:20 AM
vsg914
Looks like you have the heads on the wrong sides.... May 10 2011, 08:18 AM
sean_v8_914 Jake was being subtle. write it on a calendar and ... May 10 2011, 09:33 AM
McMark
Jake was being subtle. write it on a calendar and... May 10 2011, 10:43 AM
914Mike
Jake was being subtle. write it on a calendar an... May 10 2011, 11:34 AM
McMark
True, but it would be 'when the bellows are _... May 10 2011, 06:04 PM
enderw88
True, but it would be 'when the bellows [i]a... May 10 2011, 07:19 PM
McMark I don't like it. I decree my interpretation t... May 10 2011, 07:30 PM
enderw88
I don't like it. I decree my interpretation ... May 10 2011, 08:04 PM
sean_v8_914 gramar police should has at least 200 posts to qua... May 11 2011, 08:01 AM
914Mike
Grammar police should have at least 200 posts to ... May 13 2011, 01:28 AM
jaxdream phuch em , make hims dos a tyme aught &&... May 11 2011, 08:05 AM
MikeM Just to be clear....I'm missing some parts fro... May 12 2011, 07:38 AM
vsg914 Mike, the default is to the hot in case the cable ... May 12 2011, 09:33 AM
Mike, the default is to the hot in case the cable... May 12 2011, 10:55 AM
Root_Werks I see three major points that have been made to th... May 12 2011, 12:17 PM
MikeM Thanks guys...if I would have thought about that f... May 12 2011, 07:51 PM
avidfanjpl Mike,
On the standard temp gauge in the console i... May 12 2011, 09:24 PM
914Mike
On a cold motor, flap bolt tiedown should be... May 13 2011, 01:11 AM
avidfanjpl Everyone has an opinion based on experience on the... May 13 2011, 01:29 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th September 2026 - 12:10 PM |
