| cdadaa |
Oct 24 2010, 10:37 AM
Newbie ![]() Group: Members Posts: 6 Joined: 25-May 09 From: Spring Creek, Nevada Member No.: 10,402 Region Association: None |
Hi,
Is this the correct positioning for the cooling flaps with a cold unexpanded bellows? Somehow I think the rod may have been bent or the flaps twisted by the previous owner. I want to hook up the thermostat so I can have a wintertime heater. Thanks...Dan Attached thumbnail(s) |
| McMark |
May 10 2011, 12:00 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
ONLY attach the wire with the flaps in this position if you're sure the thermostat bellows are functioning. If your bellows have failed you will be setting up the motor for a MELTDOWN.
(IMG:http://www.914world.com/bbs2/uploads/post-10402-1287940846_thumb.jpg) |
| 914Mike |
May 10 2011, 01:20 AM
Member ![]() ![]() Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
ONLY attach the wire with the flaps in this position if you're sure the thermostat bellows are functioning. If your bellows have failed you will be setting up the motor for a MELTDOWN. Yep, BTDT (in a former life...) Connecting the cable with the flaps in that position pretty much guarantees a meltdown, whether the bellows is working or not... It's more important that the flaps OPEN fully than it is that they CLOSE fully! The technique for setting the cable clamp is to remove the bellows mounting bolt so the bellows can follow the cable when you pull it up. (The bracket acts as the stop for it.) The flaps need to be in the fully "open" or "hot" position when you tighten the cable clamp. (That's the position it is pulled to by the springs, so you don't need to move it if it is not binding.) Then pull the bellows back to it's mounting bolt and tighten the bolt. The cable will have pulled the flaps partly open.) This way makes sure that the flaps are fully open when the bellows expands as much as the bracket will allow it to. They only close as much as the contracting bellows can pull them against the springs on the rod. |
cdadaa Cooling Flaps Oct 24 2010, 10:37 AM
Sleepin That is the hot position IIRC. Oct 24 2010, 11:07 AM
StratPlayer Thermostat cable connects with the connector in th... Oct 24 2010, 11:11 AM
cdadaa So the flaps are both "up" or closed lik... Oct 24 2010, 11:21 AM
Cap'n Krusty The system in question has ABSOLUTELY NOTHING to d... Oct 24 2010, 11:53 AM
cdadaa That wasn't my question Mr. Cap'n! Oct 24 2010, 12:04 PM
Cap'n Krusty
... Oct 24 2010, 03:37 PM
Jake Raby In the HOT position the diverter over the oil cool... Oct 24 2010, 12:56 PM
abayer1969 :popcorn: Oct 24 2010, 03:39 PM
cdadaa Thanks Jake...that makes sense. I'm good to g... Oct 24 2010, 05:31 PM
gasman Looks like you have the heads on the wrong sides..... Oct 24 2010, 05:41 PM
cdadaa Look again...I believe the CHT is on the passenger... Oct 24 2010, 05:53 PM
SirAndy BTW, this is going in a 912E.
And we knew that bec... May 9 2011, 09:14 PM
jaxdream
Look again...I believe the CHT is on the passenge... May 10 2011, 07:33 AM
ziggy Were the cable running to the thermo to break, wou... May 9 2011, 08:25 PM
vsg914
Looks like you have the heads on the wrong sides.... May 10 2011, 08:18 AM
sean_v8_914 Jake was being subtle. write it on a calendar and ... May 10 2011, 09:33 AM
McMark
Jake was being subtle. write it on a calendar and... May 10 2011, 10:43 AM
914Mike
Jake was being subtle. write it on a calendar an... May 10 2011, 11:34 AM
McMark
True, but it would be 'when the bellows are _... May 10 2011, 06:04 PM
enderw88
True, but it would be 'when the bellows [i]a... May 10 2011, 07:19 PM
McMark I don't like it. I decree my interpretation t... May 10 2011, 07:30 PM
enderw88
I don't like it. I decree my interpretation ... May 10 2011, 08:04 PM
sean_v8_914 gramar police should has at least 200 posts to qua... May 11 2011, 08:01 AM
914Mike
Grammar police should have at least 200 posts to ... May 13 2011, 01:28 AM
jaxdream phuch em , make hims dos a tyme aught &&... May 11 2011, 08:05 AM
MikeM Just to be clear....I'm missing some parts fro... May 12 2011, 07:38 AM
vsg914 Mike, the default is to the hot in case the cable ... May 12 2011, 09:33 AM
Mike, the default is to the hot in case the cable... May 12 2011, 10:55 AM
Root_Werks I see three major points that have been made to th... May 12 2011, 12:17 PM
MikeM Thanks guys...if I would have thought about that f... May 12 2011, 07:51 PM
avidfanjpl Mike,
On the standard temp gauge in the console i... May 12 2011, 09:24 PM
914Mike
On a cold motor, flap bolt tiedown should be... May 13 2011, 01:11 AM
avidfanjpl Everyone has an opinion based on experience on the... May 13 2011, 01:29 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th September 2026 - 12:09 PM |
