> Cooling Flaps
cdadaa
post Oct 24 2010, 10:37 AM
Hi,
Is this the correct positioning for the cooling flaps with a cold unexpanded bellows?
Somehow I think the rod may have been bent or the flaps twisted by the previous owner. I want to hook up the thermostat so I can have a wintertime heater.
Thanks...Dan
TheCabinetmaker
post May 10 2011, 08:18 AM
I drive my car everyday
QUOTE(gasman @ Oct 24 2010, 05:41 PM) *
Looks like you have the heads on the wrong sides....Cht belongs on passenger side.....if your going to carbs...no problem....If FI, you might have to run a wire from harness to CHT...Just an observation
QUOTE(cdadaa @ Oct 24 2010, 05:53 PM) *
Look again...I believe the CHT is on the passenger side. The photo was taken from the flywheel (engine rear, front of car) side. BTW, this is going in a 912E.
QUOTE(jaxdream @ May 10 2011, 07:33 AM) *
QUOTE(cdadaa @ Oct 24 2010, 03:53 PM) *
Ok for the position of the engine in the 912E- Yes ( passenger side ) , position for the CHT sender to operate with Fuel Injection- NO , the CHT needs to be over the Number 3 cylinder to capture the hotest cylinder -per Porsche / VW configuration.
We ( the forum members ) are trying to help with some advise . Good Luck , and do hope you get it running well.
Jack / Jaxdream
They aren't trying to bust your balls. They are trying to help you save an engine. Your CHT is on the #2 cylinder. It belongs on the #3 cylinder. We can clearly see it on the drivers side. Take the time to take it apart and reassemble the it the correct way now while its only a few hour job. Haste makes waste. (IMG:style_emoticons/default/beerchug.gif)
cdadaa   Cooling Flaps   Oct 24 2010, 10:37 AM
Sleepin   That is the hot position IIRC.   Oct 24 2010, 11:07 AM
StratPlayer   Thermostat cable connects with the connector in th...   Oct 24 2010, 11:11 AM
cdadaa   So the flaps are both "up" or closed lik...   Oct 24 2010, 11:21 AM
Cap'n Krusty   The system in question has ABSOLUTELY NOTHING to d...   Oct 24 2010, 11:53 AM
cdadaa   That wasn't my question Mr. Cap'n!   Oct 24 2010, 12:04 PM
Cap'n Krusty   That wasn't my question Mr. Cap'n! ...   Oct 24 2010, 03:37 PM
Jake Raby   In the HOT position the diverter over the oil cool...   Oct 24 2010, 12:56 PM
abayer1969   :popcorn:   Oct 24 2010, 03:39 PM
cdadaa   Thanks Jake...that makes sense. I'm good to g...   Oct 24 2010, 05:31 PM
gasman   Looks like you have the heads on the wrong sides.....   Oct 24 2010, 05:41 PM
cdadaa   Look again...I believe the CHT is on the passenger...   Oct 24 2010, 05:53 PM
SirAndy   BTW, this is going in a 912E. And we knew that bec...   May 9 2011, 09:14 PM
jaxdream   Look again...I believe the CHT is on the passenge...   May 10 2011, 07:33 AM
ziggy   Were the cable running to the thermo to break, wou...   May 9 2011, 08:25 PM
McMark   ONLY attach the wire with the flaps in this positi...   May 10 2011, 12:00 AM
914Mike   ONLY attach the wire with the flaps in this posit...   May 10 2011, 01:20 AM
vsg914   Looks like you have the heads on the wrong sides....   May 10 2011, 08:18 AM
sean_v8_914   Jake was being subtle. write it on a calendar and ...   May 10 2011, 09:33 AM
McMark   Jake was being subtle. write it on a calendar and...   May 10 2011, 10:43 AM
914Mike   Jake was being subtle. write it on a calendar an...   May 10 2011, 11:34 AM
McMark   True, but it would be 'when the bellows are _...   May 10 2011, 06:04 PM
enderw88   True, but it would be 'when the bellows [i]a...   May 10 2011, 07:19 PM
McMark   I don't like it. I decree my interpretation t...   May 10 2011, 07:30 PM
enderw88   I don't like it. I decree my interpretation ...   May 10 2011, 08:04 PM
sean_v8_914   gramar police should has at least 200 posts to qua...   May 11 2011, 08:01 AM
914Mike   Grammar police should have at least 200 posts to ...   May 13 2011, 01:28 AM
jaxdream   phuch em , make hims dos a tyme aught &&...   May 11 2011, 08:05 AM
MikeM   Just to be clear....I'm missing some parts fro...   May 12 2011, 07:38 AM
vsg914   Mike, the default is to the hot in case the cable ...   May 12 2011, 09:33 AM
SirAndy   Mike, the default is to the hot in case the cable...   May 12 2011, 10:55 AM
Root_Werks   I see three major points that have been made to th...   May 12 2011, 12:17 PM
MikeM   Thanks guys...if I would have thought about that f...   May 12 2011, 07:51 PM
avidfanjpl   Mike, On the standard temp gauge in the console i...   May 12 2011, 09:24 PM
914Mike   ... On a cold motor, flap bolt tiedown should be...   May 13 2011, 01:11 AM
avidfanjpl   Everyone has an opinion based on experience on the...   May 13 2011, 01:29 AM
- Lo-Fi Version Time is now: 25th September 2026 - 12:09 PM
