OT: 1992 325i, Not passing smog |
jeffdon |
May 11 2011, 02:36 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Any BMW experts out there? Just flunked smog with Hi HC and NO at 15mph. I was ok at 25. I have replaced a cracked duct between the AF sensor and throttle body. I think I am also going to change the plugs and oil (been awhile). I replaced the O2 sensor two years ago. Anything else i should be doing?
Andyrew |
May 11 2011, 05:33 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
What were the exact numbers.
If your close, change oil and plugs and run 1 part Toutline (Tutoul, its a paint thinner/alcohol, It helps eliminate nocking) to 5 parts gas. Is your cat old? You should run the engine HARD (High RPM's) to heat up the cat very hot JUST before going on the dyno, which will help it burn the HC's. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:48 PM |
