> DIY Strings Alignment Setup
yeahmag
post May 12 2011, 11:14 AM
This was built using 80/20 hardware and a friend of mine on the mill:
yeahmag
post May 12 2011, 11:17 AM
The bars are *exactly* the same length and indexed *exactly* the same. So all I should need to do is measure off the front and rear (L & R) and I will have a parallelogram very quickly.
Krank
post May 12 2011, 11:27 PM
QUOTE(yeahmag @ May 12 2011, 12:17 PM) *
I was never a huge fan or "string" alignments that I used to do in the 70s and I am still not a fan of them. Too many discrepancies. Wheel track must be 100% the same between front and rear axles to get an accurate toe in measurement/setting. If you were to start with a true toe in setting of 1/8" and then widen the front axle wheel track by 1.00" your string method of measurement now reads a different toe reading. This is just to show the change in toe that is possible. Don't get me wrong, this method may get you close but using jack stands as string anchors would probably work just as well. Seeing as you are measuring the distance from the string to the tire 9 0'clock, axle center, and 3 o'clock positions to obtain a parallel line on each side of the car and give you an idea of toe in/out. If all you wish to accomplish is proper toe setting, a "toe bar" scribe method would be more accurate. To be honest, I have never looked up the wheel track or steer axle set back specs of a 914 and it may be exactly the same and work fine but just so you are aware that there are many vehicle that are not the same.
yeahmag   DIY Strings Alignment Setup   May 12 2011, 11:14 AM
yeahmag   The sliders at the end are indexed every 5 mm   May 12 2011, 11:14 AM
yeahmag   I'm using string here just because it was hand...   May 12 2011, 11:15 AM
yeahmag   The bars are *exactly* the same length and indexed...   May 12 2011, 11:17 AM
Krank   The bars are *exactly* the same length and indexe...   May 12 2011, 11:27 PM
SirAndy   Wheel track must be 100% the same between front an...   May 13 2011, 12:05 AM
Richard Casto   Wheel track must be 100% the same between front a...   May 13 2011, 07:08 AM
PeeGreen 914   :beer2: Nice, This is very similar to what you wou...   May 12 2011, 11:33 AM
yeahmag   I know! That part is still killing me...   May 12 2011, 11:38 AM
URY914   Leave them on and use them for curb feelers. :D   May 12 2011, 12:10 PM
Andyrew   String alignment works great for toe in/out, but I...   May 12 2011, 03:08 PM
SirAndy   I use 2 4x4's and a tape measure and a buddy.....   May 12 2011, 10:55 PM
Andyrew   I use 2 4x4's and a tape measure and a buddy....   May 13 2011, 12:58 AM
Dave_Darling   I just dont see how a string method will do the c...   May 13 2011, 10:42 PM
mrbubblehead   I just dont see how a string method will do the ...   May 14 2011, 07:54 AM
SirAndy   As long as you get the strings referenced to the a...   May 14 2011, 01:24 PM
mrbubblehead   [quote name='mrbubblehead' post='1477507' date='M...   May 14 2011, 08:34 PM
SirAndy   so the front track width is the same as the rear t...   May 14 2011, 08:39 PM
mrbubblehead   so the front track width is the same as the rear ...   May 14 2011, 08:46 PM
fasthonda   so the front track width is the same as the rear ...   May 15 2011, 07:14 AM
SirAndy   You need to take the track width into consideratio...   May 15 2011, 12:55 PM
wobbletop   You need to take the track width into considerati...   May 16 2011, 10:26 PM
Bartlett 914   You need to take the track width into considerat...   May 17 2011, 06:02 AM
whatabout1   For camber just get on flat floor (doesn't nee...   May 12 2011, 03:35 PM
Eric_Shea   How much to do a second one?   May 12 2011, 10:34 PM
yeahmag   I would guess at least $200 in parts - probab...   May 13 2011, 12:05 AM
yeahmag   This system does replace jack stands - and yes tha...   May 13 2011, 12:03 AM
914 shifter   This system does replace jack stands - and yes th...   May 15 2011, 06:11 AM
BK911   I use a setup very similar, but with electrical co...   May 14 2011, 09:18 AM
sww914   I've done hundreds of alignments with computer...   May 14 2011, 10:56 AM
zonedoubt   ...and the distance between string attachment poin...   May 14 2011, 02:40 PM
sixnotfour   ray scruggs wrote this booklet a million years ago...   May 14 2011, 04:35 PM
John   Do what you will, but I will stick with my machine...   May 14 2011, 08:41 PM
sww914   No, it might be 6 1/2" in the front to the st...   May 14 2011, 09:15 PM
mrbubblehead   No, it might be 6 1/2" in the front to the s...   May 14 2011, 09:41 PM
SirAndy   No, it might be 6 1/2" in the front to the st...   May 15 2011, 12:33 AM
sww914   Not if you measure the distance between the string...   May 15 2011, 09:14 AM
yeahmag   That's where the indexed bars come in to play....   May 15 2011, 10:51 AM
SirAndy   I did the alignment yesterday and started with a s...   May 15 2011, 12:58 PM
mrbubblehead   I did the alignment yesterday and started with a ...   May 15 2011, 03:14 PM
SirAndy   couldnt you just pop the steering wheel off and th...   May 15 2011, 07:44 PM
tradisrad   how to string align from smart racing. I am a lit...   May 17 2011, 09:19 AM
SirAndy   Is he correct with his terminology? Yes, he is cor...   May 17 2011, 12:05 PM
tradisrad   Is he correct with his terminology? Yes, he is co...   May 17 2011, 01:14 PM
enderw88   how to string align from smart racing. I am a li...   May 17 2011, 03:23 PM
yeahmag   And here are some videos from yesterday's trip...   May 17 2011, 10:22 AM
yeahmag   Remember it's the distance from the *outside* ...   May 17 2011, 12:09 PM
Rand   Remember it's the distance from the *outside*...   May 17 2011, 01:39 PM
karnak   Good info here. i have done a string alignment and...   Jun 15 2011, 08:37 PM
yeahmag   1/16" to in in the rear. 1/8" or more to...   Jun 15 2011, 08:43 PM
mrbubblehead   this is the website i used to string align my car ...   Jun 15 2011, 08:44 PM
dion9146   this is the website i used to string align my car...   Jul 22 2011, 02:12 PM
- Lo-Fi Version Time is now: 3rd October 2026 - 05:16 PM
