> Tomeric Build Thread, ...new brakes, new cooler and a video!
tomeric914
post Aug 1 2010, 04:28 PM
One Lap of America in a 914!
Back in February of '08, Cupomeat and Tomeric914 picked up this lovely 916 replica and a boatload of spare parts:
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280701715.1.jpg)
Clean, one owner, Florida car, runs great, blah, blah, blah... When we picked it up, one carb was seized and the PO was "working on it". "Does the engine turn over?", I ask. "Last I knew it did", he says.
Yea, maybe not:
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280701715.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280701716.3.jpg)
Our first clue was when we pulled the oil drain plug and nothing came out. It was about 20 degrees in the garage so the water on the bottom of the engine was frozen. After using a torch to melt the water, the oil came out.
http://www.youtube.com/watch?v=VuK9Z7fpgic
The video above shows a nice ice cube stuck to the float of the one Weber that was still in the car. The PO said the car ran hot so they remove the rain tray to get more air in the engine compartment. The filters didn't have rain hats on and there were 1/4" to 1/2" gaps around the bottoms of the filters. The PO had made up some cheesedick plate for the bottom of the filter on but didn't understand the concept of flatness.
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280701717.4.jpg)
That was only the beginning of the fun. I've already forgotten about all the other half-assed fixes the PO did. My goal was to get the car on the road by April and on the track by the end of the summer.
The PO had relocated the battery to the trunk which I wasn't crazy about. They also did some hellhole repair that looked to be ok. I finished their repair and but the battery tray back where it should be. At the same time, I rebuilt the 2.0 engine using A LOT of the spare parts we had (heads were one of those spare parts). What amazed me was the amount of parts that were in their original shipping boxes dated from the mid 1980's with 2nd day air! They sat for 20+ years!
Here is the engine in the car around the middle of April all set to go.
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280701717.5.jpg)
So now it has 96mm KB pistons and AA cylinders (which, BTW suck. AA used to have decent cylinders). It is now a 2056 with 40IDFs and what appears to be an old S&S exhaust setup. I put the lowest profile tires I could find on the crappy set of cookie cutters we had.
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280708541.1.jpg)
For the next few months I drive it and sort out the various issues, rebuild all the brake calipers, remove the brake line tee that the DAPO put in and get a nice reconditioned brake pressure regulator from PMB. Sign up for my first track event at Watkins Glen and before going there, install an oil cooler.
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280708542.2.jpg)
Then I found some rust in the long that needed attention. Luckily, not too bad... yet. Cut it out and repair it.
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280708542.3.jpg)
Then off to the Glen!
PanelBilly
post May 13 2011, 08:36 AM
I need to component you on the nice balance of restoration vs. function. At least that's the wY it looks like from the thread.
tomeric914
post May 13 2011, 09:32 AM
Thanks PB. That means a lot to me considering the level of perfection that I've seen from your threads!
I think I've got a few good shots of the 245's on the rear with flares.
I will try in earnest to update this thread over the weekend. I flared and painted it last year then dropped a six in it over the winter.
tomeric914   Tomeric Build Thread   Aug 1 2010, 04:28 PM
tomeric914   At the Glen, the car feels a little loose in the r...   Aug 1 2010, 07:00 PM
Ericv1   Nice, I'm liking the 916 front and rear. If p...   Aug 1 2010, 07:31 PM
tomeric914   Oops, I can't forget the garage floor rebuild ...   Aug 1 2010, 08:01 PM
Cupomeat   Having seen pix throughout this process, it is ama...   Aug 2 2010, 09:13 AM
Nürburg Nomad   Have any updates and particularly current side pro...   May 13 2011, 01:39 AM
Cairo94507   Wow! Very nice work and I too like the stock ...   May 13 2011, 06:58 AM
rick 918-S   Drive it like ya stole it! :headbanger:   May 13 2011, 07:06 AM
PanelBilly   I need to component you on the nice balance of res...   May 13 2011, 08:36 AM
tomeric914   Thanks PB. That means a lot to me considering the...   May 13 2011, 09:32 AM
PeeGreen 914   I like the progression :beer2: . Looking good :hea...   May 13 2011, 09:40 AM
Cupomeat   No doubt that you have made HUGE changes on this c...   May 13 2011, 09:41 AM
abnrdo   :beer2: Nice work!! Inspiration for me wh...   May 14 2011, 04:00 AM
tomeric914   Getting back to it, I'll start back at May 201...   May 15 2011, 10:02 AM
FourBlades   Great work man, keep the pictures coming. I also ...   May 15 2011, 10:39 AM
tomeric914   I also like how you have kept it on the road most...   May 15 2011, 10:51 AM
markb   :wub:   May 15 2011, 10:58 AM
tomeric914   From the start of this build, the priorities were:...   May 15 2011, 06:11 PM
Cupomeat   As always Tom, First Class work! Looks great...   May 15 2011, 09:33 PM
jaxdream   I could be wrong , but looks like you are missing ...   May 16 2011, 08:52 AM
ewdysar   Nice work, Tom! I'm getting ready to ge...   May 16 2011, 11:50 AM
tomeric914   I could be wrong , but looks like you are missing...   May 16 2011, 12:08 PM
jaxdream   I could be wrong , but looks like you are missin...   Jun 2 2011, 04:32 PM
tomeric914   Update: Finished up the exhaust. This is a Magan...   May 22 2011, 06:49 PM
tomeric914   Update: Finally done with the breather. There...   May 28 2011, 11:06 AM
Cupomeat   Looks GREAT! I guess it is more of a NARP wit...   Jun 1 2011, 03:05 PM
tomeric914   Yea, but the breather says Moroso so it must be fa...   Jun 1 2011, 06:20 PM
kconway   Are those breather/catch cans required for street ...   Jun 1 2011, 08:01 PM
tomeric914   Are those breather/catch cans required for street...   Jun 2 2011, 10:17 AM
nsr-jamie   You do great work!! Car looks excellent no...   Jun 1 2011, 09:37 PM
Cupomeat   You do great work!! Car looks excellent n...   Jun 1 2011, 09:50 PM
tomeric914   My solution to turn the oil cooler fan on: Honda ...   Jun 15 2011, 09:27 PM
Cupomeat   My solution to turn the oil cooler fan on: Honda...   Jun 15 2011, 09:39 PM
pete-stevers   I spotted a single cab in one of those pics.....   Jun 15 2011, 11:49 PM
tomeric914   I spotted a single cab in one of those pics..... ...   Jun 16 2011, 06:31 AM
tomeric914   So I tackled the oil leaks from my chain boxes wit...   Jun 26 2011, 09:16 PM
Eric_Shea   Looking great Tom! I like the fact that you ...   Jun 28 2011, 09:29 PM
Cupomeat   Looking great Tom! I like the fact that you ...   Jul 1 2011, 08:54 AM
tomeric914   Eric, according to your logical pattern recogniti...   Jul 1 2011, 03:52 PM
Cupomeat   Good point, fixing brakes BEFORE something breaks ...   Jul 2 2011, 09:14 PM
Cupomeat   Good point, fixing brakes BEFORE something breaks...   Jul 3 2011, 08:36 PM
Cupomeat   Having had a ride now, all I can say is that I wan...   Jul 3 2011, 08:56 PM
tomeric914   Great car, and sorry about your air dam(n) Tom. ...   Jul 4 2011, 06:27 PM
tomeric914   ok, so I've been busy with a few things and ha...   Aug 14 2011, 09:45 AM
AZ914   The cooler looks great! I'm about to add ...   Aug 14 2011, 04:14 PM
Scarlet75   I really need to get down there and check this 914...   Aug 14 2011, 04:19 PM
tomeric914   The cooler looks great! I'm about to add...   Aug 14 2011, 09:23 PM
tomeric914   I've been busy this winter working on a couple...   Mar 25 2012, 09:54 AM
Cupomeat   Damn, looking forward to seeing this car in July. ...   Apr 20 2012, 01:41 PM
tomeric914   Damn, looking forward to seeing this car in July....   Apr 20 2012, 03:53 PM
rick 918-S   Very nice!   Apr 21 2012, 06:11 AM
jmill   Still one of my favorite cars. :trophy:   Apr 21 2012, 10:47 AM
tomeric914   Still one of my favorite cars. :trophy: Thanks...   Apr 21 2012, 02:29 PM
tomeric914   I need to get more pictures up, but in the meantim...   May 19 2012, 07:42 PM
Cupomeat   Fantastic!!! You almost have your dai...   May 19 2012, 10:09 PM
tomeric914   More progress: Added another layer of Damplifier ...   Jul 5 2012, 06:36 AM
JmuRiz   Looking good, good to know the rear cooler was onl...   Aug 2 2012, 01:37 PM
FourBlades   More nice work! How do you like the kirkey se...   Aug 3 2012, 08:52 AM
tomeric914   Looking good, good to know the rear cooler was on...   Aug 3 2012, 08:04 PM
Cupomeat   A good shot of Tom at WG. That car is amazingly f...   Sep 6 2012, 04:44 PM
tomeric914   Going faster means I need to scrub off more speed ...   Sep 6 2012, 07:15 PM
somd914   Tom, Awesome build. I'm loving your old 2056...   Sep 8 2012, 06:34 AM
tomeric914   Been busy this winter but haven't posted much ...   Apr 5 2014, 08:42 PM
jaxdream   Forgive my ignorance Tom , what was the "bloc...   Apr 6 2014, 09:14 AM
tomeric914   Forgive my ignorance Tom , what was the "blo...   Apr 6 2014, 09:41 AM
tomeric914   Finally added my Sheridan rear spoiler. One of th...   Apr 7 2014, 09:12 PM
arkitect   Cool thread, have not seen this type of rear spoil...   May 2 2015, 10:18 AM
tomeric914   Cool thread, have not seen this type of rear spoi...   May 2 2015, 12:58 PM
Maltese Falcon   Excellent craftsmanship here Tom...I dig the silve...   May 2 2015, 03:58 PM
Luke M   Hey Tom, Nice car you got there. Would you be wil...   May 3 2015, 06:48 PM
tomeric914   Just updating my thread with post I recently made...   Jun 30 2017, 06:49 PM
tomeric914   With the Christmas break, I finally took the time ...   Jan 14 2018, 11:02 AM
Cupomeat   Looks great! Let's see if the rotor cracki...   Jan 15 2018, 01:00 PM
totle   Tomeric, can you please share a picture of how you...   Sep 7 2018, 02:18 AM
tomeric914   ...can you please share a picture of how you rout...   Sep 7 2018, 04:07 PM
totle   Thanks. Ok, thought you routed it outside the heat...   Sep 8 2018, 02:49 PM
tomeric914   Late update... A few years ago, when @cupomeat ...   Jan 19 2020, 12:24 PM
tomeric914   Well apparently I have not updated this thread in ...   Feb 10 2023, 09:50 PM
tomeric914   More updates incoming. After 12 years of abuse an...   Feb 18 2023, 06:35 PM
930cabman   just happened on this build, thanks for documentin...   Dec 21 2025, 01:52 PM
tomeric914   Is your only teener a track car? It does both. ...   Dec 21 2025, 06:55 PM
barefoot   Is your only teener a track car? It does both. ...   Dec 25 2025, 08:59 AM
tomeric914   Yes, committing to a cage & race seat with 5 ...   Dec 25 2025, 09:42 AM
mgp4591   How are you liking the Corrado brake m/c? I'v...   Dec 21 2025, 11:37 PM
tomeric914   How are you liking the Corrado brake m/c? I...   Dec 22 2025, 07:51 AM
930cabman   From what i could see there was some "heavy...   Dec 22 2025, 09:46 AM
Cupomeat   Yeah, I even did a bunch of videos for that OLOA, ...   Dec 28 2025, 02:15 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 08:21 PM
