| yeahmag |
May 12 2011, 11:14 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,485 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
| Andyrew |
May 12 2011, 03:08 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
String alignment works great for toe in/out, but IMHO I dont see it helping with camber or caster...
I use 2 4x4's and a tape measure and a buddy... Then drive to the alignment shop and pay the man $50 to tell me I did it right and give me a printout of camber/caster/toe/"walk". (IMG:style_emoticons/default/biggrin.gif) I also use a bubble camber guage... Cross between the two below. http://cgi.ebay.com/ebaymotors/New-Aluminu...=item2eb4cc14e1 http://cgi.ebay.com/ebaymotors/Tenhulzen-A...=item4aab1e936e |
| SirAndy |
May 12 2011, 10:55 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,533 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I use 2 4x4's and a tape measure and a buddy... Then drive to the alignment shop and pay the man $50 to tell me I did it right and give me a printout of camber/caster/toe/"walk". (IMG:style_emoticons/default/biggrin.gif) The problem with that is that a two wheel alignment does not ensure the whole car is square. We use camber plates at the track for quick setups, but you're only setting the front or the rear at any given time. If the car is not squared, you'll be crabbing down the road ... (IMG:style_emoticons/default/shades.gif) |
| Andyrew |
May 13 2011, 12:58 AM
I use 2 4x4's and a tape measure and a buddy... Then drive to the alignment shop and pay the man $50 to tell me I did it right and give me a printout of camber/caster/toe/"walk". (IMG:style_emoticons/default/biggrin.gif) The problem with that is that a two wheel alignment does not ensure the whole car is square. We use camber plates at the track for quick setups, but you're only setting the front or the rear at any given time. If the car is not squared, you'll be crabbing down the road ... (IMG:style_emoticons/default/shades.gif) Which is why you go to the alignment shop that has lazers and pay the men 50 bucks to do the car the rest of the way... (IMG:style_emoticons/default/biggrin.gif) The 4x4 method works great for those quick jobs if you just did something and need to drive somewhere. I just dont see how a string method will do the car to the level that a daily driver should be at to prevent premature tire wear. |
| Dave_Darling |
May 13 2011, 10:42 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,364 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I just dont see how a string method will do the car to the level that a daily driver should be at to prevent premature tire wear. As long as you get the strings referenced to the actual centerline if the car, you can get it as good with strings as you can with lasers. In fact, you get the exact same problem with the lasers; they have to be referenced to the centerline of the car to make sure the car doesn't crab. The track widths are completely irrelevant, you measure the tire (or the wheel) against the centerline, not the front wheel against the back wheel. --DD |
| mrbubblehead |
May 14 2011, 07:54 AM
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
I just dont see how a string method will do the car to the level that a daily driver should be at to prevent premature tire wear. As long as you get the strings referenced to the actual centerline if the car, you can get it as good with strings as you can with lasers. In fact, you get the exact same problem with the lasers; they have to be referenced to the centerline of the car to make sure the car doesn't crab. The track widths are completely irrelevant, you measure the tire (or the wheel) against the centerline, not the front wheel against the back wheel. --DD so how is the best way to find the center line of the care. |
| SirAndy |
May 14 2011, 01:24 PM
As long as you get the strings referenced to the actual centerline if the car, you can get it as good with strings as you can with lasers. In fact, you get the exact same problem with the lasers; they have to be referenced to the centerline of the car to make sure the car doesn't crab. The track widths are completely irrelevant, you measure the tire (or the wheel) against the centerline, not the front wheel against the back wheel. so how is the best way to find the center line of the car. You simply use the strings. Measure the distance from the string to the wheel hub in the front left and right until they are even. Then measure the distance from the string to the wheel hub in the rear left and right until they are even. Double check front and rear until both are even left/right (Equal numbers per axle). At that point, the strings are parallel to the car and have equal distance from the centerline. (IMG:style_emoticons/default/bye1.gif) |
| mrbubblehead |
May 14 2011, 08:34 PM
As long as you get the strings referenced to the actual centerline if the car, you can get it as good with strings as you can with lasers. In fact, you get the exact same problem with the lasers; they have to be referenced to the centerline of the car to make sure the car doesn't crab. The track widths are completely irrelevant, you measure the tire (or the wheel) against the centerline, not the front wheel against the back wheel. so how is the best way to find the center line of the car. You simply use the strings. Measure the distance from the string to the wheel hub in the front left and right until they are even. Then measure the distance from the string to the wheel hub in the rear left and right until they are even. Double check front and rear until both are even left/right (Equal numbers per axle). At that point, the strings are parallel to the car and have equal distance from the centerline. (IMG:style_emoticons/default/bye1.gif) so the front track width is the same as the rear track width on our 914's? and when you say "wheel hub" do you mean the tip of the axles? |
| SirAndy |
May 14 2011, 08:39 PM
so the front track width is the same as the rear track width on our 914's? and when you say "wheel hub" do you mean the tip of the axles? No. Track width is completely unimportant for any of this. When i say "hub" i mean whatever is in the center of the wheel. The strings need to line up with the center of the wheel and you measure from the string to the hub or any other reference of your liking. To set the actual toe, you measure the distance of the front edge and rear edge of the same wheel. That difference can then be used to calculate your toe. (IMG:style_emoticons/default/shades.gif) |
| fasthonda |
May 15 2011, 07:14 AM
914 Type R ![]() ![]() Group: Members Posts: 148 Joined: 10-January 04 From: Simpsonville, SC Member No.: 1,544 Region Association: None |
so the front track width is the same as the rear track width on our 914's? and when you say "wheel hub" do you mean the tip of the axles? No. Track width is completely unimportant for any of this. When i say "hub" i mean whatever is in the center of the wheel. The strings need to line up with the center of the wheel and you measure from the string to the hub or any other reference of your liking. To set the actual toe, you measure the distance of the front edge and rear edge of the same wheel. That difference can then be used to calculate your toe. (IMG:style_emoticons/default/shades.gif) You need to take the track width into consideration or the strings will not be parallel. The rear track width of the 914 is 1 icnh greater than the front. You need to add 1/2 inch when setting the distance from the front hub vs the rear to achieve parallelism. |
yeahmag DIY Strings Alignment Setup May 12 2011, 11:14 AM
yeahmag The sliders at the end are indexed every 5 mm
yeahmag I'm using string here just because it was hand... May 12 2011, 11:15 AM
yeahmag The bars are *exactly* the same length and indexed... May 12 2011, 11:17 AM
Krank
The bars are *exactly* the same length and indexe... May 12 2011, 11:27 PM
SirAndy Wheel track must be 100% the same between front an... May 13 2011, 12:05 AM
Richard Casto
Wheel track must be 100% the same between front a... May 13 2011, 07:08 AM
PeeGreen 914 :beer2: Nice, This is very similar to what you wou... May 12 2011, 11:33 AM
yeahmag I know! That part is still killing me... May 12 2011, 11:38 AM
URY914 Leave them on and use them for curb feelers. :D May 12 2011, 12:10 PM
mrbubblehead
so the front track width is the same as the rear ... May 14 2011, 08:46 PM
SirAndy You need to take the track width into consideratio... May 15 2011, 12:55 PM
wobbletop
You need to take the track width into considerati... May 16 2011, 10:26 PM
Bartlett 914
You need to take the track width into considerat... May 17 2011, 06:02 AM
whatabout1 For camber just get on flat floor (doesn't nee... May 12 2011, 03:35 PM
Eric_Shea
How much to do a second one? May 12 2011, 10:34 PM
yeahmag I would guess at least $200 in parts - probab... May 13 2011, 12:05 AM
yeahmag This system does replace jack stands - and yes tha... May 13 2011, 12:03 AM
914 shifter
This system does replace jack stands - and yes th... May 15 2011, 06:11 AM
BK911 I use a setup very similar, but with electrical co... May 14 2011, 09:18 AM
sww914 I've done hundreds of alignments with computer... May 14 2011, 10:56 AM
zonedoubt ...and the distance between string attachment poin... May 14 2011, 02:40 PM
sixnotfour ray scruggs wrote this booklet a million years ago... May 14 2011, 04:35 PM
John Do what you will, but I will stick with my machine... May 14 2011, 08:41 PM
sww914 No, it might be 6 1/2" in the front to the st... May 14 2011, 09:15 PM
mrbubblehead
No, it might be 6 1/2" in the front to the s... May 14 2011, 09:41 PM
SirAndy No, it might be 6 1/2" in the front to the st... May 15 2011, 12:33 AM
sww914 Not if you measure the distance between the string... May 15 2011, 09:14 AM
yeahmag That's where the indexed bars come in to play.... May 15 2011, 10:51 AM
SirAndy I did the alignment yesterday and started with a s... May 15 2011, 12:58 PM
mrbubblehead
I did the alignment yesterday and started with a ... May 15 2011, 03:14 PM
SirAndy couldnt you just pop the steering wheel off and th... May 15 2011, 07:44 PM
tradisrad how to string align from smart racing.
I am a lit... May 17 2011, 09:19 AM
SirAndy Is he correct with his terminology?
Yes, he is cor... May 17 2011, 12:05 PM
tradisrad
Yes, he is co... May 17 2011, 01:14 PM
enderw88
I am a li... May 17 2011, 03:23 PM
yeahmag And here are some videos from yesterday's trip... May 17 2011, 10:22 AM
yeahmag Remember it's the distance from the *outside* ... May 17 2011, 12:09 PM
Rand
Remember it's the distance from the *outside*... May 17 2011, 01:39 PM
karnak Good info here. i have done a string alignment and... Jun 15 2011, 08:37 PM
yeahmag 1/16" to in in the rear. 1/8" or more to... Jun 15 2011, 08:43 PM
mrbubblehead this is the website i used to string align my car ... Jun 15 2011, 08:44 PM
dion9146
this is the website i used to string align my car... Jul 22 2011, 02:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd October 2026 - 05:14 PM |
