> DIY Strings Alignment Setup
yeahmag
post May 12 2011, 11:14 AM
This was built using 80/20 hardware and a friend of mine on the mill:
Andyrew
post May 12 2011, 03:08 PM
Spooling.... Please wait
String alignment works great for toe in/out, but IMHO I dont see it helping with camber or caster...
I use 2 4x4's and a tape measure and a buddy... Then drive to the alignment shop and pay the man $50 to tell me I did it right and give me a printout of camber/caster/toe/"walk". (IMG:style_emoticons/default/biggrin.gif)
I also use a bubble camber guage... Cross between the two below.
http://cgi.ebay.com/ebaymotors/New-Aluminu...=item2eb4cc14e1
http://cgi.ebay.com/ebaymotors/Tenhulzen-A...=item4aab1e936e
post May 12 2011, 10:55 PM
Resident German
QUOTE(Andyrew @ May 12 2011, 02:08 PM) *
The problem with that is that a two wheel alignment does not ensure the whole car is square.
We use camber plates at the track for quick setups, but you're only setting the front or the rear at any given time.
If the car is not squared, you'll be crabbing down the road ...
Andyrew
post May 13 2011, 12:58 AM
QUOTE(SirAndy @ May 12 2011, 09:55 PM) *
Which is why you go to the alignment shop that has lazers and pay the men 50 bucks to do the car the rest of the way... (IMG:style_emoticons/default/biggrin.gif)
The 4x4 method works great for those quick jobs if you just did something and need to drive somewhere. I just dont see how a string method will do the car to the level that a daily driver should be at to prevent premature tire wear.
Dave_Darling
post May 13 2011, 10:42 PM
914 Idiot
QUOTE(Andyrew @ May 12 2011, 11:58 PM) *
As long as you get the strings referenced to the actual centerline if the car, you can get it as good with strings as you can with lasers. In fact, you get the exact same problem with the lasers; they have to be referenced to the centerline of the car to make sure the car doesn't crab.
The track widths are completely irrelevant, you measure the tire (or the wheel) against the centerline, not the front wheel against the back wheel.
--DD
mrbubblehead
post May 14 2011, 07:54 AM
Twodollardoug
QUOTE(Dave_Darling @ May 13 2011, 09:42 PM) *
--DD
so how is the best way to find the center line of the care.
post May 14 2011, 01:24 PM
Resident German
QUOTE(mrbubblehead @ May 14 2011, 06:54 AM) *
so how is the best way to find the center line of the car.
You simply use the strings.
Measure the distance from the string to the wheel hub in the front left and right until they are even.
Then measure the distance from the string to the wheel hub in the rear left and right until they are even.
Double check front and rear until both are even left/right (Equal numbers per axle).
At that point, the strings are parallel to the car and have equal distance from the centerline.
mrbubblehead
post May 14 2011, 08:34 PM
Twodollardoug
QUOTE(SirAndy @ May 14 2011, 12:24 PM) *
so the front track width is the same as the rear track width on our 914's? and when you say "wheel hub" do you mean the tip of the axles?
post May 14 2011, 08:39 PM
Resident German
QUOTE(mrbubblehead @ May 14 2011, 07:34 PM) *
No. Track width is completely unimportant for any of this.
When i say "hub" i mean whatever is in the center of the wheel. The strings need to line up with the center of the wheel and you measure from the string to the hub or any other reference of your liking.
To set the actual toe, you measure the distance of the front edge and rear edge of the same wheel. That difference can then be used to calculate your toe.
fasthonda
post May 15 2011, 07:14 AM
914 Type R
QUOTE(SirAndy @ May 14 2011, 06:39 PM) *
You need to take the track width into consideration or the strings will not be parallel. The rear track width of the 914 is 1 icnh greater than the front. You need to add 1/2 inch when setting the distance from the front hub vs the rear to achieve parallelism.
wobbletop
post May 16 2011, 10:26 PM
QUOTE(fasthonda @ May 15 2011, 09:14 AM) *
That's close but the camber difference between front and rear will make the distance slightly different than the difference in track.
Bartlett 914
post May 17 2011, 06:02 AM
QUOTE(wobbletop @ May 16 2011, 11:26 PM) *
Not if you measure at the center of the wheel.
yeahmag   DIY Strings Alignment Setup   May 12 2011, 11:14 AM
yeahmag   The sliders at the end are indexed every 5 mm   May 12 2011, 11:14 AM
yeahmag   I'm using string here just because it was hand...   May 12 2011, 11:15 AM
yeahmag   The bars are *exactly* the same length and indexed...   May 12 2011, 11:17 AM
Krank   The bars are *exactly* the same length and indexe...   May 12 2011, 11:27 PM
SirAndy   Wheel track must be 100% the same between front an...   May 13 2011, 12:05 AM
Richard Casto   Wheel track must be 100% the same between front a...   May 13 2011, 07:08 AM
PeeGreen 914   :beer2: Nice, This is very similar to what you wou...   May 12 2011, 11:33 AM
yeahmag   I know! That part is still killing me...   May 12 2011, 11:38 AM
URY914   Leave them on and use them for curb feelers. :D   May 12 2011, 12:10 PM
Andyrew   String alignment works great for toe in/out, but I...   May 12 2011, 03:08 PM
SirAndy   I use 2 4x4's and a tape measure and a buddy.....   May 12 2011, 10:55 PM
Andyrew   I use 2 4x4's and a tape measure and a buddy....   May 13 2011, 12:58 AM
Dave_Darling   I just dont see how a string method will do the c...   May 13 2011, 10:42 PM
mrbubblehead   I just dont see how a string method will do the ...   May 14 2011, 07:54 AM
SirAndy   As long as you get the strings referenced to the a...   May 14 2011, 01:24 PM
mrbubblehead   [quote name='mrbubblehead' post='1477507' date='M...   May 14 2011, 08:34 PM
SirAndy   so the front track width is the same as the rear t...   May 14 2011, 08:39 PM
mrbubblehead   so the front track width is the same as the rear ...   May 14 2011, 08:46 PM
fasthonda   so the front track width is the same as the rear ...   May 15 2011, 07:14 AM
SirAndy   You need to take the track width into consideratio...   May 15 2011, 12:55 PM
wobbletop   You need to take the track width into considerati...   May 16 2011, 10:26 PM
Bartlett 914   You need to take the track width into considerat...   May 17 2011, 06:02 AM
whatabout1   For camber just get on flat floor (doesn't nee...   May 12 2011, 03:35 PM
Eric_Shea   How much to do a second one?   May 12 2011, 10:34 PM
yeahmag   I would guess at least $200 in parts - probab...   May 13 2011, 12:05 AM
yeahmag   This system does replace jack stands - and yes tha...   May 13 2011, 12:03 AM
914 shifter   This system does replace jack stands - and yes th...   May 15 2011, 06:11 AM
BK911   I use a setup very similar, but with electrical co...   May 14 2011, 09:18 AM
sww914   I've done hundreds of alignments with computer...   May 14 2011, 10:56 AM
zonedoubt   ...and the distance between string attachment poin...   May 14 2011, 02:40 PM
sixnotfour   ray scruggs wrote this booklet a million years ago...   May 14 2011, 04:35 PM
John   Do what you will, but I will stick with my machine...   May 14 2011, 08:41 PM
sww914   No, it might be 6 1/2" in the front to the st...   May 14 2011, 09:15 PM
mrbubblehead   No, it might be 6 1/2" in the front to the s...   May 14 2011, 09:41 PM
SirAndy   No, it might be 6 1/2" in the front to the st...   May 15 2011, 12:33 AM
sww914   Not if you measure the distance between the string...   May 15 2011, 09:14 AM
yeahmag   That's where the indexed bars come in to play....   May 15 2011, 10:51 AM
SirAndy   I did the alignment yesterday and started with a s...   May 15 2011, 12:58 PM
mrbubblehead   I did the alignment yesterday and started with a ...   May 15 2011, 03:14 PM
SirAndy   couldnt you just pop the steering wheel off and th...   May 15 2011, 07:44 PM
tradisrad   how to string align from smart racing. I am a lit...   May 17 2011, 09:19 AM
SirAndy   Is he correct with his terminology? Yes, he is cor...   May 17 2011, 12:05 PM
tradisrad   Is he correct with his terminology? Yes, he is co...   May 17 2011, 01:14 PM
enderw88   how to string align from smart racing. I am a li...   May 17 2011, 03:23 PM
yeahmag   And here are some videos from yesterday's trip...   May 17 2011, 10:22 AM
yeahmag   Remember it's the distance from the *outside* ...   May 17 2011, 12:09 PM
Rand   Remember it's the distance from the *outside*...   May 17 2011, 01:39 PM
karnak   Good info here. i have done a string alignment and...   Jun 15 2011, 08:37 PM
yeahmag   1/16" to in in the rear. 1/8" or more to...   Jun 15 2011, 08:43 PM
mrbubblehead   this is the website i used to string align my car ...   Jun 15 2011, 08:44 PM
dion9146   this is the website i used to string align my car...   Jul 22 2011, 02:12 PM
- Lo-Fi Version Time is now: 3rd October 2026 - 05:15 PM
