| yeahmag |
May 12 2011, 11:14 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,485 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
| tradisrad |
May 17 2011, 09:19 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
how to string align from smart racing.
I am a little confused on his instruction where he says " Toe-in: the measurement is longer on the leading edge of the wheel than the trailing edge of the wheel." This seems backwards to me and he has it switched with "Toe-out: the measurement is shorter on the leading edge of the wheel than the trailing edge of the wheel." Is he correct with his terminology? |
| SirAndy |
May 17 2011, 12:05 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,533 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Is he correct with his terminology? Yes, he is correct. The distance on the front edge (leading edge) of the wheel will be larger for toe-in. (IMG:style_emoticons/default/shades.gif) |
yeahmag DIY Strings Alignment Setup May 12 2011, 11:14 AM
yeahmag The sliders at the end are indexed every 5 mm
yeahmag I'm using string here just because it was hand... May 12 2011, 11:15 AM
yeahmag The bars are *exactly* the same length and indexed... May 12 2011, 11:17 AM
Krank
The bars are *exactly* the same length and indexe... May 12 2011, 11:27 PM
SirAndy Wheel track must be 100% the same between front an... May 13 2011, 12:05 AM
Richard Casto
Wheel track must be 100% the same between front a... May 13 2011, 07:08 AM
PeeGreen 914 :beer2: Nice, This is very similar to what you wou... May 12 2011, 11:33 AM
yeahmag I know! That part is still killing me... May 12 2011, 11:38 AM
URY914 Leave them on and use them for curb feelers. :D May 12 2011, 12:10 PM
Andyrew String alignment works great for toe in/out, but I... May 12 2011, 03:08 PM
SirAndy I use 2 4x4's and a tape measure and a buddy..... May 12 2011, 10:55 PM
Andyrew
I use 2 4x4's and a tape measure and a buddy.... May 13 2011, 12:58 AM
Dave_Darling I just dont see how a string method will do the c... May 13 2011, 10:42 PM
mrbubblehead
I just dont see how a string method will do the ... May 14 2011, 07:54 AM
SirAndy As long as you get the strings referenced to the a... May 14 2011, 01:24 PM
mrbubblehead
[quote name='mrbubblehead' post='1477507' date='M... May 14 2011, 08:34 PM
SirAndy so the front track width is the same as the rear t... May 14 2011, 08:39 PM
mrbubblehead
so the front track width is the same as the rear ... May 14 2011, 08:46 PM
fasthonda
so the front track width is the same as the rear ... May 15 2011, 07:14 AM
SirAndy You need to take the track width into consideratio... May 15 2011, 12:55 PM
wobbletop
You need to take the track width into considerati... May 16 2011, 10:26 PM
Bartlett 914
You need to take the track width into considerat... May 17 2011, 06:02 AM
whatabout1 For camber just get on flat floor (doesn't nee... May 12 2011, 03:35 PM
Eric_Shea
How much to do a second one? May 12 2011, 10:34 PM
yeahmag I would guess at least $200 in parts - probab... May 13 2011, 12:05 AM
yeahmag This system does replace jack stands - and yes tha... May 13 2011, 12:03 AM
914 shifter
This system does replace jack stands - and yes th... May 15 2011, 06:11 AM
BK911 I use a setup very similar, but with electrical co... May 14 2011, 09:18 AM
sww914 I've done hundreds of alignments with computer... May 14 2011, 10:56 AM
zonedoubt ...and the distance between string attachment poin... May 14 2011, 02:40 PM
sixnotfour ray scruggs wrote this booklet a million years ago... May 14 2011, 04:35 PM
John Do what you will, but I will stick with my machine... May 14 2011, 08:41 PM
sww914 No, it might be 6 1/2" in the front to the st... May 14 2011, 09:15 PM
mrbubblehead
No, it might be 6 1/2" in the front to the s... May 14 2011, 09:41 PM
SirAndy No, it might be 6 1/2" in the front to the st... May 15 2011, 12:33 AM
sww914 Not if you measure the distance between the string... May 15 2011, 09:14 AM
yeahmag That's where the indexed bars come in to play.... May 15 2011, 10:51 AM
SirAndy I did the alignment yesterday and started with a s... May 15 2011, 12:58 PM
mrbubblehead
I did the alignment yesterday and started with a ... May 15 2011, 03:14 PM
SirAndy couldnt you just pop the steering wheel off and th... May 15 2011, 07:44 PM
tradisrad
Yes, he is co... May 17 2011, 01:14 PM
enderw88
I am a li... May 17 2011, 03:23 PM
yeahmag And here are some videos from yesterday's trip... May 17 2011, 10:22 AM
yeahmag Remember it's the distance from the *outside* ... May 17 2011, 12:09 PM
Rand
Remember it's the distance from the *outside*... May 17 2011, 01:39 PM
karnak Good info here. i have done a string alignment and... Jun 15 2011, 08:37 PM
yeahmag 1/16" to in in the rear. 1/8" or more to... Jun 15 2011, 08:43 PM
mrbubblehead this is the website i used to string align my car ... Jun 15 2011, 08:44 PM
dion9146
this is the website i used to string align my car... Jul 22 2011, 02:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd October 2026 - 05:16 PM |
