> Yet another car won't start thread. FIXED!, No click, no starter spin, nothing
Jakeodoule
post May 19 2011, 06:49 PM
76 2.0 stock FI
Lucky for me its in my garage. Last time I drove it, it was all smiles!
When I turn the key the FI charges and all lights seem normal.
I get no click from the starter and no spin.
Starter is less than 3000 miles old and was working fine. If I jump the terminals on the starter it spins.
I have a solid AGM battery, 13 volts to starter on big power line.
All fuses are good and wiring harness is totally stock and unmolested.
I get no power to the brown wire on the starter soleniod when the key is turned.
Is there a relay for this?
(IMG:style_emoticons/default/WTF.gif)
BTW I did do a search but most info is related to cranking but not starting.
Any ideas?
Jakeodoule
post May 20 2011, 07:53 AM
Yep I have a multimeter. I am a field Engineer in electronics....
I did ohm out the new switch after it did not fix the problem.
This is quite baffling. I understand how the starter works.
If I put 12 volts to the terminal on the starter solenoid the car starts and runs fine.
Its got to be a broken wire. I just don't know which pin that comes off the relay board. If I had that, I can check voltage there and ohm the wire from the switch to the board as well as from the relay board to the starter.
Anyone know where those come and go from the relay board?
Jakeodoule   Yet another car won't start thread. FIXED!   May 19 2011, 06:49 PM
Jakeodoule   Changed the relay board and ignition switch. No Lu...   May 19 2011, 09:08 PM
Jakeodoule   Changed the switch. Its not that. Its also not the...   May 19 2011, 09:55 PM
Kirmizi   Just for giggles have you checked the relay (seatb...   May 19 2011, 10:31 PM
Cap'n Krusty   There is no relay under the seat on a '76. Th...   May 19 2011, 10:35 PM
Kirmizi   Doh! Thanks Cap'n. Learn something everyda...   May 19 2011, 10:38 PM
Jakeodoule   Yep there is a relay under the pass seat. or was. ...   May 19 2011, 10:47 PM
mrgjones   Wait, the starter solenoid IS the relay for the st...   May 19 2011, 11:32 PM
Jakeodoule   Yep I have a multimeter. I am a field Engineer in ...   May 20 2011, 07:53 AM
aircooledtechguy   There is a Bosch starter relay kit P/N WR1 that fi...   May 20 2011, 08:49 AM
Jakeodoule   That is interesting Nate. Thanks! The Dash lig...   May 20 2011, 08:57 AM
Tom   Jake, First off, there should be a yellow wir...   May 20 2011, 09:21 AM
Jakeodoule   Jake, First off, there should be a yellow wi...   May 20 2011, 09:41 AM
tradisrad   yellow wire to the relay board is from the ignitio...   May 20 2011, 10:16 AM
Jakeodoule   yellow wire to the relay board is from the igniti...   May 20 2011, 10:23 AM
Jakeodoule   Thanks to all for the assistance and to you Tradis...   May 20 2011, 02:39 PM
Vacca Rabite   So I cut it open and soldered it back up and I am...   May 20 2011, 10:01 PM
Jakeodoule   There is differing opinions on that subject to be ...   May 20 2011, 10:40 PM
messix   soldering at a fixed terminus is where there would...   May 20 2011, 10:54 PM
- Lo-Fi Version Time is now: 4th July 2025 - 11:34 AM
