> Yet another car won't start thread. FIXED!, No click, no starter spin, nothing
Jakeodoule
post May 19 2011, 06:49 PM
76 2.0 stock FI
Lucky for me its in my garage. Last time I drove it, it was all smiles!
When I turn the key the FI charges and all lights seem normal.
I get no click from the starter and no spin.
Starter is less than 3000 miles old and was working fine. If I jump the terminals on the starter it spins.
I have a solid AGM battery, 13 volts to starter on big power line.
All fuses are good and wiring harness is totally stock and unmolested.
I get no power to the brown wire on the starter soleniod when the key is turned.
Is there a relay for this?
(IMG:style_emoticons/default/WTF.gif)
BTW I did do a search but most info is related to cranking but not starting.
Any ideas?
Jakeodoule
post May 20 2011, 10:40 PM
There is differing opinions on that subject to be sure.
However I personally have had way more trouble with those crimp connectors after use and age than I have with connections that are soldered properly.
If you clean the wire, use a high grade solder, Solder it correctly and use heat shrink it will hold.
I would not solder ends that flex constantly. But this is in the middle and I make a good solid connection with the wire first and then solder them. I do not rely on the solder for the connection.
I would suggest you use whatever method works best for you.
Jakeodoule   Yet another car won't start thread. FIXED!   May 19 2011, 06:49 PM
Jakeodoule   Changed the relay board and ignition switch. No Lu...   May 19 2011, 09:08 PM
Jakeodoule   Changed the switch. Its not that. Its also not the...   May 19 2011, 09:55 PM
Kirmizi   Just for giggles have you checked the relay (seatb...   May 19 2011, 10:31 PM
Cap'n Krusty   There is no relay under the seat on a '76. Th...   May 19 2011, 10:35 PM
Kirmizi   Doh! Thanks Cap'n. Learn something everyda...   May 19 2011, 10:38 PM
Jakeodoule   Yep there is a relay under the pass seat. or was. ...   May 19 2011, 10:47 PM
mrgjones   Wait, the starter solenoid IS the relay for the st...   May 19 2011, 11:32 PM
Jakeodoule   Yep I have a multimeter. I am a field Engineer in ...   May 20 2011, 07:53 AM
aircooledtechguy   There is a Bosch starter relay kit P/N WR1 that fi...   May 20 2011, 08:49 AM
Jakeodoule   That is interesting Nate. Thanks! The Dash lig...   May 20 2011, 08:57 AM
Tom   Jake, First off, there should be a yellow wir...   May 20 2011, 09:21 AM
Jakeodoule   Jake, First off, there should be a yellow wi...   May 20 2011, 09:41 AM
tradisrad   yellow wire to the relay board is from the ignitio...   May 20 2011, 10:16 AM
Jakeodoule   yellow wire to the relay board is from the igniti...   May 20 2011, 10:23 AM
Jakeodoule   Thanks to all for the assistance and to you Tradis...   May 20 2011, 02:39 PM
Vacca Rabite   So I cut it open and soldered it back up and I am...   May 20 2011, 10:01 PM
Jakeodoule   There is differing opinions on that subject to be ...   May 20 2011, 10:40 PM
messix   soldering at a fixed terminus is where there would...   May 20 2011, 10:54 PM
- Lo-Fi Version Time is now: 4th July 2025 - 11:42 AM
