HELP! 72 914 1.7 not starting |
914_classic |
May 17 2011, 07:52 PM
Newbie Group: Members Posts: 12 Joined: 2-April 11 From: West Michigan Member No.: 12,887 Region Association: Upper MidWest |
Got it out a few weeks ago and it wont start. It will start when you fog the intake with starting fluid. Im going to start testing fuel pressure. first after the pump, then after the filter, then after the regulator. I don't have a noid light to check the injector signal, but they are grounded.
any ideas?... thanks! (IMG:style_emoticons/default/driving.gif) |
914_classic |
May 24 2011, 04:37 PM
The car has sufficient fuel pressure coming out of the pressure regulator. I got a set of noid lights and have found that i have no signal going to the injectors. I also have lost spark, I have it coming out of the coil but not into the plug wires. I remember reading that there are injector triggers on the distributor. could my points be bad and thats why i have no fuel or spark?
p.s. still cant figure why the fuel pump runs constantly instead of just priming... |
Lo-Fi Version | Time is now: 10th June 2024 - 12:36 PM |
