> This can't be right?, D-Jet
FlatSix
post May 21 2011, 08:13 AM
English Member
Background:
Car is 1976, and has not been driven for many years (don't ask). The engine is now a 1.7 from 1970. I have replaced all hoses, fuel lines and fuel pump.
Problem:
The engine will start, run for a few minutes then stop however when the engine is running the fuel pressure is ZERO! Activating the fuel pump by pressing the relay in the engine compartment with my finger brings the fuel pressure up to 28psi and stalls the engine.
The car will NOT then restart. When trying to restart I CANNOT always hear the fuel pump run. The fuel presure is 28psi though.
Aim:
To get the engine running as it should.
McMark
post May 26 2011, 10:53 AM
914 Freak!
Joe, some pictures of the box and part would be extremely appreciated! (IMG:style_emoticons/default/smiley_notworthy.gif)
FlatSix   This can't be right?   May 21 2011, 08:13 AM
trojanhorsepower   Let me forward with " I don't know anythi...   May 21 2011, 08:26 AM
Cap'n Krusty   Right off the bat, where did you tap the fuel syst...   May 21 2011, 08:28 AM
FlatSix   I took a video to help explain better: uCmqITLZS...   May 21 2011, 08:30 AM
FlatSix   Hmm... that didn't work as well as I hoped...   May 21 2011, 08:34 AM
FlatSix   I had the fuel injectors serviced. The fuel press...   May 21 2011, 08:36 AM
SLITS   Doesn't sound quite right. Where is your fuel...   May 21 2011, 08:37 AM
FlatSix   YouTube video here: <object width="425...   May 21 2011, 08:38 AM
scotty b   http://www.914world.com/bbs2/index.php?sho...g+you...   May 21 2011, 08:47 AM
FlatSix   Here you go uCmqITLZSrM   May 21 2011, 08:55 AM
ConeDodger   Pull your relay board and look for greenish crap c...   May 21 2011, 09:04 AM
FlatSix   I've just changed the relay board but the symp...   May 21 2011, 09:29 AM
SLITS   In your video, there are a couple of things: 1.) ...   May 21 2011, 09:51 AM
ConeDodger   Have you tried switching the relays around...   May 21 2011, 10:32 AM
Root_Werks   You're running off the cold start injector and...   May 21 2011, 10:49 AM
FlatSix   I have swapped the relays around - no difference. ...   May 21 2011, 10:59 AM
70-914nut   i had the exact problem. fuel lines we incorrectly...   May 21 2011, 03:35 PM
mrgjones   Somebody correct me if I'm wrong. The fact tha...   May 21 2011, 04:02 PM
swl   damn this is a weird one! Lets go back to bas...   May 22 2011, 07:01 AM
SLITS   damn this is a weird one! Another weird (to ...   May 22 2011, 07:36 AM
swl   There is a check valve in the pump that holds pre...   May 22 2011, 08:01 AM
FlatSix   I've taken the tank out and checked the fuel l...   May 22 2011, 07:43 AM
SLITS   I've taken the tank out and checked the fuel ...   May 22 2011, 08:07 AM
swl   yup. pushing down the plate closes 30-87. pump s...   May 22 2011, 07:47 AM
FlatSix   I have a suspicion that two wrongs may make a righ...   May 22 2011, 07:53 AM
swl   I have a suspicion that two wrongs may make a rig...   May 22 2011, 08:10 AM
John   What I believe that some were saying before about ...   May 22 2011, 08:07 AM
SLITS   As far as the tank connections go, there are 2 co...   May 22 2011, 08:14 AM
swl   Steve, if you have pulled the connections off th...   May 22 2011, 08:29 AM
SLITS   The fuel pumps used on these (and many other cars)...   May 22 2011, 08:46 AM
swl   so all the speculation aside the right thing to do...   May 22 2011, 09:04 AM
SLITS   Yep .... I just don't remember which port the...   May 22 2011, 09:11 AM
FlatSix   The fuel fumes have got to me today, the informati...   May 22 2011, 09:16 AM
SLITS   Damn Andy ... 1.) Fuse on relay board .... is it...   May 22 2011, 09:30 AM
Spoke   Here's what the fuel lines on my 1.7L DJET loo...   May 22 2011, 09:56 AM
swl   You can only really debug it in the "won...   May 22 2011, 10:13 AM
FlatSix   Looking at Ron's list: Fues on relay board - ...   May 22 2011, 10:33 AM
ConeDodger   Looking at Ron's list: Fues on relay board -...   May 22 2011, 10:56 AM
swl   Fues on relay board - Isn't this 'downstr...   May 23 2011, 06:23 AM
FlatSix   That's the problem I now have - intermittent f...   May 22 2011, 11:05 AM
SLITS   Last question .... you said you replaced the fuel ...   May 22 2011, 11:06 AM
McMark   First things first. Does the fuel pump run for 2 ...   May 22 2011, 11:39 AM
FlatSix   I did make the mistake of buying an 'OEM' ...   May 22 2011, 11:47 AM
Spoke   1. Sometimes the fuel pump will run for 2 seconds...   May 22 2011, 11:52 AM
swl   2. After running for about 2 minutes (cold?) the ...   May 23 2011, 06:38 AM
FlatSix   I've made some progress. I've taken apart ...   May 24 2011, 10:09 AM
r_towle   wiring... ohm your FI harness to verify you dont h...   May 24 2011, 10:43 AM
FlatSix   In trying to test the CHT white harness wire it br...   May 24 2011, 11:15 AM
r_towle   Jeff Bowlsby makes complete new FI harness setups....   May 24 2011, 11:21 AM
FlatSix   I'm thinking a new harness would be the most r...   May 24 2011, 01:31 PM
Rockaria   has anyone mentioned checking the ignition switch....   May 24 2011, 09:51 PM
FlatSix   Christopher, Having thought about this a bit now, ...   May 26 2011, 04:10 AM
porscheless   Christopher, Having thought about this a bit now,...   May 26 2011, 06:15 AM
McMark   Joe, some pictures of the box and part would be ex...   May 26 2011, 10:53 AM
r_towle   Joe, some pictures of the box and part would be e...   May 26 2011, 02:56 PM
porscheless   Here it is! It is for a 76, which I think goe...   May 26 2011, 03:50 PM
FlatSix   That photo was just too much for me. I've just...   May 27 2011, 02:34 AM
SLITS   3 different switches '69 - mid '72 .... h...   May 27 2011, 07:01 AM
FlatSix   I ordered the same part number as in the picture. ...   May 27 2011, 10:31 AM
KELTY360   This link will take you through it step by step. ...   May 27 2011, 11:02 AM
r_towle   your at the wrong end ,,,, Remove the plastic col...   May 27 2011, 11:10 AM
FlatSix   The Pelican article was good but a little vauge fo...   May 27 2011, 12:23 PM
FlatSix   The good news is that the old switch was cracked. ...   May 27 2011, 12:26 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:56 PM
