stock93 |
Member ![]() ![]() Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States ![]() |
I have a 2.0 type IV engine with 44idfs on it. I was going to sync the carbs today and noticed that even when not pumping the throttle the accelerator pump drips a stream of gas down into the throat of the carb enough that its pooling up a bit on the throttle plate. I'm getting popping back through the carbs. Timing is spot on and the valves are correctly adjusted. I take it this is a problem and they arent supposted to do this? It also smells like its still running to rich. I have 135 mains, 200 airs, 55 idles, 36mm vents, and no velocity stacks currently. Mixture screws are set 1.5 turns out. Its also hesitating from idle to around 3K rpm if I step on it hard like its flooding out. Time to put kits in the carbs? Does the jetting for the accelerator pump need to be changed or adjusted?
John |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
I'm running 55 idles in 40IDFs with 28 vents on a nearly stock 1.7, with no plug fouling problems. 50s were too lean (bucking at light throttle). I'm a still rich now (idle mixture screws down to 1 turn out, and plugs are still black), and will probably drop to 52s, but it runs cleanly with the 55s, and I'm getting gas mileage in the low 20s, so it has to be close.
Lo-Fi Version | Time is now: 4th July 2025 - 08:30 PM |
