HELP! 72 914 1.7 not starting |
914_classic |
May 17 2011, 07:52 PM
Newbie Group: Members Posts: 12 Joined: 2-April 11 From: West Michigan Member No.: 12,887 Region Association: Upper MidWest |
Got it out a few weeks ago and it wont start. It will start when you fog the intake with starting fluid. Im going to start testing fuel pressure. first after the pump, then after the filter, then after the regulator. I don't have a noid light to check the injector signal, but they are grounded.
any ideas?... thanks! (IMG:style_emoticons/default/driving.gif) |
914_classic |
May 29 2011, 10:12 AM
So I got signal to the fuel injectors. Its was the power supply relay, got it replaced. While I was testing things out I noticed the fuel pump was running even though there was no relays or fuses in the relay board. I proceeded to aquire spark (condensor and coil), although its weak. Went to start it and now the fuel pump wont turn on at all. I put the battery charger on it and the pump pulsed slowly, then stopped. It has been relocated under the tank, which is going to make this 10 times harder. I also believe PO just wired the fuel pump straight into the ign switch but I cant find any wires. Any ideas?
Lo-Fi Version | Time is now: 2nd June 2024 - 04:15 AM |
