| BCinSC |
May 29 2011, 08:42 AM
Nothing but Trouble ![]() ![]() Group: Members Posts: 138 Joined: 8-June 03 From: Wakefield, MA Member No.: 800 Region Association: North East States |
So Blanche ('73 White 914-4 1.7L) was running great last summer until she simply stopped on I-95 in Burlington, MA. Simply no spark anymore. Having no time to deal with it, she sat until today. I figured out the spark problem, but now the fuel pump, won't. Familiar with this type of issue, I open the relay board and check the fuse and the relay. I've got 12V where I'm suppose to - both sides of fuse, pin85 of FP relay when key on (FI Brain energizes to close circuit to join pin30 and pin87 I believe). PIN13 of connector closest to firewall, which diagram says goes out to FP itself, shows continuity to ground, so I'm guessing broken wire somewhere. Sounds reasonable/plausible? Fuel Pump was functional before I put her away.
| BCinSC |
May 29 2011, 12:17 PM
Hooked up known good spark plug to wire #1 and cranked. No spark. Back to square one. Suggestions?
BCinSC Fuel Pump will not run May 29 2011, 08:42 AM
SLITS Pumps do gum up or fail.
Run hot wire to + termin... May 29 2011, 09:05 AM
Elliot Cannon
Run hot wire to + termi... May 29 2011, 09:13 AM
SLITS
Run hot wire to + term... May 29 2011, 09:37 AM
Elliot Cannon
[quote name='Elliot Cannon' post='1485200' date='... May 29 2011, 01:38 PM
BCinSC Is that Gumby with a Blunt? Anyway, I think you a... May 29 2011, 09:12 AM
Tom Bruce,
Just went thru this yesterday with anot... May 29 2011, 09:12 AM
BCinSC Argh. Swapped pumps and same deal. Could FI Brai... May 29 2011, 10:11 AM
SLITS
Argh. Swapped pumps and same deal. Could FI Bra... May 29 2011, 10:16 AM
BCinSC I don't get it. I have 12V at Pin30 of Relay.... May 29 2011, 10:26 AM
BCinSC Mess with it long enough, and miraculously, it wil... May 29 2011, 10:34 AM
Tom The relays sometimes don't fit tight in the so... May 29 2011, 10:51 AM
BCinSC Not quite the contortionist I used to be. Can... May 29 2011, 12:09 PM
benalishhero No spark? Are you running points and condensor? May 29 2011, 01:03 PM
BCinSC Yes. Both relatively new (couple thousand miles a... May 29 2011, 01:34 PM
BCinSC I reiterate that I was doing 60+ on the highway wh... May 29 2011, 01:36 PM
Elliot Cannon I just had a crap load of electrical problems with... May 29 2011, 01:42 PM
BCinSC Checked points more closely and found that the met... May 29 2011, 02:59 PM
djm914-6 Sounds like you're having fun. WHo's watch... May 29 2011, 03:08 PM
BCinSC Kids in Maine. 3 dogs in kennel. Other 4 milling... May 29 2011, 06:36 PM
djm914-6 That's odd.... was the registry open today? May 29 2011, 06:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th August 2026 - 06:01 AM |
