> Hello world..., Intro/question
Dark Hobo
post Jun 2 2011, 04:39 AM
USMC
Hello, my name is Ian. I am a 23 year old marine and am currently on a forced extended vacation to the beautiful ( (IMG:style_emoticons/default/headbang.gif) ) Yuma Arizona. I Just bought my first 914 back in march in my home state after years of loving them and a year of searching. I drove it down from Oregon, where I am from and where I bought it, to Yuma Arizona where I am stationed. I got a hold of a '74 2.0L originally white but repainted saturn yellow I think. She is pretty faded and has been a one family car since they bought her. The guy's family had saved every receipt on maintenance they ever had done on the car (IMG:style_emoticons/default/blink.gif) . Outside of some quirks and general wear and tear she seems to be in amazing condition. Just glad to say I finally own a 914 (IMG:style_emoticons/default/smilie_pokal.gif) .
Anyways I have been talking with my dad a lot about various things since he has a boatload of knowledge about VWs and pretty much any other classic car in existence. But he is less confident about some things and suggested I pose some of my questions here, this and some parts I want to buy have brought me out of lurking (IMG:style_emoticons/default/smile.gif).
First I guess was when I bought it the brakes didn't squeal at all. But within the past few weeks they started squealing. They go up and down on how bad it is. I bought some brake pads and went to replace them but they still have a lot of pad left. This kinda threw me for a loop since if it was improper installation of the brake pads the noise would have manifested much earlier it seems. The rotors look pretty bad and my dad says about an 1/8in ridge is the threshold it seems like it is getting there or is there.
Second gonna check in the daytime later today but the windows leak near the top. And I think I just discovered why on the classic thread forum. I may have an early top and from what I read on there '74 has late windows and won't seal on early tops. Anyone know of an easy way to tell early from late windows?
Third, The car was having some terrible bucking problems at around a 1/4 tank of gas left. I figured it was some crap in the tank and ran some cleaner through it a few times alternating with injector cleaner. after a couple weeks I ran it down to empty almost to see if it fixed it and it seemed to. You guys think I should pull the tank out anyways to check it?
Fourth, recommendations for oil for the Yuma summer. It gets up to 130 routinely here and I was researching oil to put in it. Some said 10w50 for high temps, some said 10w40 is fine, a few even said 30 is fine. I did some research and far from being and expert settled on 40 for now until I do an oil change. But I am looking at what to put in it for my upcoming oil change in the next few weeks probably. I was looking at synthetic but it has an oil leak, it doesn't seem TOO bad though. I read that synthetics will either make and existing leak worse due to the smaller molecules or find more possible leaks if you had none. How much does the problem amplify, is it something to be worried about or could I just bite the bullet with my wallet and say screw it for the good of the car in the long run.
Sorry for the length of the post and I don't expect anyone to read it all or answer it all (IMG:style_emoticons/default/tongue.gif). Just kind of tired and need to go to sleep now. This website was a great help to me when I was looking to buy a 914 and has already helped me learn a lot of things about my car in the short time I have owned it. Will definitely be sticking around here as much as possible. Welp 'nuff rambling I guess, sleep time before my next post. Night guys and tanks to anyone that answers anything, says welcome, hello, or even just reads the first sentence.
Cap'n Krusty
post Jun 2 2011, 09:44 AM
Cap'n Krusty
German cars don't use squeal producing wear indicators on their brake systems, so brake squeal isn't indicative of pad wear. Too much light breaking, ineven rotor wear (like those big ridges at the edges) and pad hardening or contamination can cause squeal. I'd suggest living with it until the pads are nearly gone, then doing pads, rotors, and rubber brake hoses. High quality stock components, properly installed, will give way more brakes than you'll ever need.Early windows have little rollers in the channel, late windows have felt tracks. Brad Penn 20w50, ONLY. When you change the fuel filter, give some thought to replacing the adapter hose from the fuel inlet tube to the filter. If the old one looks old, replace it. There's been (for years) a quality issue with the plastic filters. We use a filter from a BMW 2002 Tii. Longer, round, and the right size connections. If you're changing any other fuel hoses, I recommend the OE replacement 7 or 7.5mm German FI rated fuel hose, along with proper FI hose clamps. Available from GPR and other sources, as close as your mailbox or the big brown truck.
Welcome aboard! Nice to have you with us!
The Cap'n
Dark Hobo   Hello world...   Jun 2 2011, 04:39 AM
ArtechnikA   first - :wttc: I must tell you it is a PLEASURE...   Jun 2 2011, 05:16 AM
hot_shoe914   first - :wttc: I must tell you it is a PLEASUR...   Jun 2 2011, 06:10 AM
Gint   first - :wttc: I must tell you it is a PLEASURE...   Jun 2 2011, 06:52 PM
arkitect   Ian, I am glad you found a good 914 in good runnin...   Jun 2 2011, 06:31 AM
carr914   :wttc: Semper Fi It sounds like good advice so ...   Jun 2 2011, 06:45 AM
rick 918-S   Here's a Brad Penn locator. http://locator.bra...   Jun 2 2011, 07:08 AM
Cairo94507   By all means, Welcome, great introduction and it s...   Jun 2 2011, 07:13 AM
flipb   I can't believe I'm the first person to sa...   Jun 2 2011, 07:28 AM
Mr.242   :wttc: ONLY THING YOU NEED TO START: 1)Jackstan...   Jun 2 2011, 07:38 AM
KELTY360   :wttc: The beauty of the 914 is that once you ge...   Jun 2 2011, 07:39 AM
nsr-jamie   Welcome aboard. My brakes squeel too recently....p...   Jun 2 2011, 07:53 AM
Dave_Darling   You may be able to address the squeaking by sandin...   Jun 2 2011, 08:51 AM
zymurgist   :wttc: :flag1:   Jun 2 2011, 08:55 AM
Cap'n Krusty   German cars don't use squeal producing wear in...   Jun 2 2011, 09:44 AM
Dark Hobo   Well, can't get pics to work on my phone so I ...   Jun 2 2011, 03:12 PM
ArtechnikA   ...Every once in awhile when I come to a stop and...   Jun 2 2011, 03:29 PM
poorsche914   snip... the VIN is 4742916690. ....snip This VIN i...   Jun 2 2011, 04:05 PM
Cap'n Krusty   snip... the VIN is 4742916690. ....snip This VIN ...   Jun 2 2011, 07:04 PM
poorsche914   [quote name='poorsche914' post='1487533' date='Ju...   Jun 2 2011, 08:19 PM
Drums66   .....Welcome to the World :shades2: :toke: :wa...   Jun 2 2011, 03:48 PM
Madswede   Could be that infamous Yuma dust getting in betwee...   Jun 2 2011, 04:12 PM
wingnut86   ...I have no comment other than... Welcome to Ear...   Jun 2 2011, 07:28 PM
914coop   :wttc:   Jun 2 2011, 09:00 PM
markb   :wttc: & :ttiwwp: 914's are an addicti...   Jun 2 2011, 09:17 PM
bandjoey   WELCOME. Ditto's to all said and the SEARCH bu...   Jun 2 2011, 09:51 PM
Jeff Bowlsby   VIN 16690 is within the LE VIN range...:) It is a...   Jun 2 2011, 10:34 PM
moparrob   WELCOME! My '74 is number 16514, so they ...   Jun 2 2011, 11:28 PM
Jeff Bowlsby   My '74 is number 16514, so they are pretty cl...   Jun 2 2011, 11:36 PM
abnrdo   :wttc: As a fellow military member, welcome to t...   Jun 2 2011, 11:36 PM
Dark Hobo   Gonna check right now... I may change plans and go...   Jun 3 2011, 03:29 AM
RiqueMar   Oh yeah, I despise how the younger ilk of my gene...   Jun 3 2011, 08:46 AM
Jeff Bowlsby   Ian, any update on your car status as an LE?   Jun 8 2011, 02:06 PM
Dark Hobo   Finally got some pics. Took me forever, but here i...   Jul 24 2011, 11:18 PM
Cairo94507   Nice looking car; thanks for the pictures.   Jul 25 2011, 05:45 AM
SUNAB914   SWEET looking car. Semper Fi Marine. Don't get...   Jul 25 2011, 08:44 AM
Dark Hobo   At this point it would seem that a witticism about...   Jul 25 2011, 10:27 PM
- Lo-Fi Version Time is now: 4th July 2025 - 06:10 PM
