Intake studs, What heads are these? |
jsaum |
Jun 4 2011, 09:20 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
So I was a happy 914 owner, just got a great deal on a set of dual carbs and went to install them when I found that the two top studs seem to be pitched at an angle! WTF! This engine is from a parts car that's going to go into my 72, I thought I would dial everything in before I did the swap. My question is what type of heads are these? Also I bought the intake gaskets that have the insulator plates it now looks like I'll have to use a regular thin ones, where can I find them? I'll get the dremel out and make the intakes fit, I guess!
Thanks, Jsaum Attached image(s) |
URY914 |
Jun 6 2011, 05:57 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,017 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Yep, pulling studs is easy. Then just use a bolt instead of a stud. I'm using bolts with allen heads (socket head cap screws) on my car. With the intakes I'm using, I couldn't get a socket on the nut and using a open end wrench was a slow PITA. So I took the studs out and replaced them with allen head bolts. Much easier now to pull the intakes off.
Lo-Fi Version | Time is now: 6th June 2024 - 09:33 PM |
