Crash207 |
Newbie ![]() Group: Members Posts: 17 Joined: 23-May 11 From: United States Member No.: 13,108 Region Association: Rocky Mountains ![]() |
Hey guys.
73 1.7 D-Jet. 3 port Bosch fuel pump (now located under the fuel tank) runs constantly and is a bit loud. I read that it is supposed to run for 1-1.5 seconds and stop with key on engine off. Checked wiring and found it is wired directly to Fuse #8 on the fuse panel. Where should it be wired? Side note. Car sat for 5 years before i rescued it and the fuel pump had power but didn't run until i whacked it a few times. Thanks in advance, You guys are awesome and your expertise is much appreciated. |
jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
Hey guys. 73 1.7 D-Jet. 3 port Bosch fuel pump (now located under the fuel tank) runs constantly and is a bit loud. I read that it is supposed to run for 1-1.5 seconds and stop with key on engine off. Checked wiring and found it is wired directly to Fuse #8 on the fuse panel. Where should it be wired? Side note. Car sat for 5 years before i rescued it and the fuel pump had power but didn't run until i whacked it a few times. Thanks in advance, You guys are awesome and your expertise is much appreciated. If you look under the car right behind the passenger seat, there is usually a white plug hainging there, or mabey ziptied up in the bay. If the PO rewired it direct to the fuse box, I would suspect there is an aftermarket switch in the cabin eithere on the dash or center console to kill it (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 14th June 2024 - 02:42 PM |
