> Intake studs, What heads are these?
jsaum
post Jun 4 2011, 09:20 PM
So I was a happy 914 owner, just got a great deal on a set of dual carbs and went to install them when I found that the two top studs seem to be pitched at an angle! WTF! This engine is from a parts car that's going to go into my 72, I thought I would dial everything in before I did the swap. My question is what type of heads are these? Also I bought the intake gaskets that have the insulator plates it now looks like I'll have to use a regular thin ones, where can I find them? I'll get the dremel out and make the intakes fit, I guess!
Thanks,
Jsaum
SLITS
post Jun 9 2011, 07:11 AM
"This Utah shit is HARSH!"
The carbs were essentially the same as used on the 1.8 Euro motors and Type 2 motors. A little restrictive for the Type 4 if you want to be a Ricky Racer, but setup correctly will give you good gas mileage.
Don't know about the quality of EMPIs. Actually I don't do carbs on anything anymore except my weed whacker.
jsaum   Intake studs   Jun 4 2011, 09:20 PM
Hammy   1.7/1.8 heads.   Jun 4 2011, 09:59 PM
70_914   Are you talking pitched at an angle as in crooked ...   Jun 4 2011, 10:57 PM
McMark   Could be Bus 2.0 heads as well.   Jun 5 2011, 12:05 PM
Spoke   looks like I'll have to use a regular thin on...   Jun 5 2011, 12:24 PM
underthetire   The one on the right sure looks bent.   Jun 5 2011, 02:00 PM
jsaum   No they're not bent i can see the threads are ...   Jun 5 2011, 02:32 PM
jsaum   Here's better pictures. The one stud maybe sli...   Jun 5 2011, 02:47 PM
vsg914   The vents are susposed to have hoses running to a ...   Jun 5 2011, 03:22 PM
vsg914   btw, using a jamb nut-two nuts tighened together o...   Jun 5 2011, 03:25 PM
McMark   Yeah, don't worry about pulling that stud. Do...   Jun 5 2011, 11:39 PM
URY914   Yep, pulling studs is easy. Then just use a bolt i...   Jun 6 2011, 05:57 AM
Cap'n Krusty   There's precious little material where the int...   Jun 6 2011, 07:38 AM
Root_Werks   There's precious little material where the in...   Jun 6 2011, 10:38 AM
HAM Inc   Those are 1.7 heads.   Jun 6 2011, 11:23 AM
jsaum   O.K. cool at least I know what they are at this po...   Jun 6 2011, 02:18 PM
charliew   Put two nuts on the stud and then put a deep scoke...   Jun 6 2011, 04:31 PM
Cap'n Krusty   Put two nuts on the stud and then put a deep scok...   Jun 6 2011, 07:04 PM
URY914   I gotta go with the Cap't here. You will most ...   Jun 6 2011, 07:34 PM
jsaum   O.K. I got seven of the studs out two were bent an...   Jun 6 2011, 10:48 PM
URY914   Did you day EMPI 34's??? All this work for EMP...   Jun 7 2011, 03:07 AM
jsaum   Did you day EMPI 34's??? All this work for EM...   Jun 8 2011, 11:12 PM
SLITS   The carbs were essentially the same as used on the...   Jun 9 2011, 07:11 AM
- Lo-Fi Version Time is now: 1st June 2024 - 08:23 AM
